Hello, there is a sign on the scren: print unable, see troubleshooting in the manual. there is no such an option in the quick setup guide
  • 805 Answers
Which brand. please write first
Posted on Jul 03, 2010
My printer says unable to print 4F
Hi!
Kept getting a "Unable to Print see Maintainace and Troubleshooting Guide" message.Only thing to do was clean the platen(?). Not the easiest part to find. They should make it another color... Finally called Brother...Went through the "key in blah,blah, and blah" bit. LCD Flashed error code 4F. Guy on the helpline didn't know what it meant(!!). Gave me an area repair shop. I'd like to know the code meaning so I can(if need be)make sure that the shop doesn't try to rip me off(repair est./self-repair instruc. would be nice from here, too). Thanks!
Regards,
c
Apr 10, 2013 | Brother MFC-J410W Wireless Compact...
Operation manual available? Quick guide available for IP 560 POLY
Hello Nicola,
You can find the user guides, setup and maintenance documents from polycom.com. Here is the link:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip560.html
Jul 29, 2009 | Polycom SoundPoint® IP 560 IP Phone
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
I can't print to my printer zm400
When you install the driver, do you get a test print from the driver setup? If the data light blinks, this is at least a sign that something is coming and the printer is aware of it. If you feel knowledgeable of the printer to do a Media Sensor setup through the menu, you can reset the printer to Factory Default settings. Getting any print from the machine is a plus. Are you using the Zebra drivers? If yes, you can try printing from Notepad.
Apr 26, 2009 | Zebra Printer 140-751-00000
IMac connection to lanier ld122
Does this printer have the PS option installed? If not you will be unable to print even if you clear up the network issue.
As far as network goes is it currently connected and working with other PCs?
Mac printing is easily setup by typing the IP address of equip in the queue box upon setup. I believe the default queue name is "print" all lower case. If IP in unable to work properly make sure lanier has appletalk turned on and setup printer using appletalk.
Again if the machine doesn't have Postscript option you won't be able to print anything.
Hope this helps,
TankMurdock
Apr 23, 2009 | Office Equipment & Supplies
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
k24674
