Question about Kenmore Oasis HE 27082 Top Load Washer
Clicking Noise I have a new sound that has developed on my top loading Oasis HE. It sounds as if something has gotten under the plate on the bottom of the machine. Is there any way to take this bottom plate off to see if there is something under there? Is there a service manual for this machine anywhere? JK
    Genius:
  • 1,028 Answers
Small cap in middle of plate pops out bolt underneath ..remove it and plate pulls up
Posted on Apr 19, 2008
Sounds like loose pieces clicking inside washer during spin cycle
Can you tell from the sound if the noise is near the bottom or not? The sound could be from something stuck in the pump. If you can post the whole model number, I can find more information..
Aug 06, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
Dec 23, 2017 | Maytag LAT3600A Top Load Washer
WILL NOT FULLY DRAIN IN LAST SPIN CYCLE
sounds like you have something clogging the intake to drain pump. open the top and remove the basket. at the bottom of the tub you will see a filter plate with 1/4" screws. remove and clean also check the hole into the pump for any obstruction. if this does not cure call for service.
Jan 23, 2012 | Kenmore Oasis HE 27082 Top Load Washer
Drains but will not spin an makes a clicking noise
Sounds like the coupling between the motor and the transmission is bad. Remove the motor and install the coupling. Put the motor back on. Should be ready to go
Jul 14, 2009 | Whirlpool LSR7333 Top Load Washer
Oasis HE - top load appears to make a noise like you hear in from a dryer when drying jeans or coats with zippers/buttons hitting the sides of the dryer. The washing machine is making this noise when...
It's likely from an overfilled load where something got between the tub and drum.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 01, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Noise sounds like loose change or screws.
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Jun 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
57 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
