Loose pin trapped between drumm and water tank
A bra wire has slipped through the drum wholes and I can't figure out how to retrieve it. No instructions to be found in the owner's manual. And when on high spin, it makes a lot of noise and I'm afraid it could damage the machine.
  • 1,557 Answers
This problem has been going on ever since wire bras meet fully auto washers the only way to remove it is to take the drum out and tip the machine upside down its a simple job but does reqwire some level of knowledge as to how to do it as all machines are different but the main thing is it cant hurt your washer the average washer after 5 yrs has around 7 wires stuck in it so unless the noise is driving you mad my best advice is ignore it they are designed to deal with these types of problems if you do wish to service the washer please feel free to email me with the make and model and i will write you a how to do diagram to remove the drum
sonicnboomelectronics@hotmail.com
Posted on Jul 03, 2010
How to remove a bra wire from behind drum in tumble dryer
Somehow they always end up in some inaccessible spot. Go to www.repairclinic.com and enter the model of your dryer. You will be presented with a list of common replacement parts and may be able to view a generic video showing disassembly for bra wire retrieval. Good luck.
Feb 18, 2017 | Dryers
Have a bra wire trapped in drum
If you remove heater element you should be able to grab bra wire and remove simply
Apr 06, 2010 | Creda W120VW Front Load Washer
Bra underwire stuck in Bosch WAE22461AU
You can try using a very high strength magnet to bring the clip up to a hole in the tub so that you can then use a pair of fine long nose pliers to grasp it and reef the little blighter out!
Patience Does It !
Oct 24, 2009 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
My frigdaire front load washer ate my underwire bra wire
Do not attempt to remove a drum unless you have been trained to do so
First thing to do is to dump the back drain hose into a big dish and drain off all of the standing water
in the machines sump.
Remove the power !!
Tip the machine towards the back and front to get as much water out of it as possible
Tip the machine back agains a wall or a bench with a cloth protecting both surfaces
Put a wooden block underneath the front edge of the machine in case it falls on you
Get a torch and look at the bottom of the drum , there will be a big hose connected to the base with a jubilee clip or spring clip
Remove the clip and pull the hose off , place a cloth on the floor as there may still be some water in the hose , if you are lucky the wire will be either in the hose or in the sump that the hose is fixed to.
If the hose is connected to the rear of the drum tip the machine as far back as possible allowing the wire to fall within reach of the hole
If you cant see it get a magnetic retriever or a piece of bent coat hanger and go fishing.
If the hose is fitted to the front of the drum reverse the machine and lay it on its front or as far forward as possible , that way the wire will fall towards the hole
Jun 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Jun 01, 2009 | Zanussi FJS1225W Front Load Washer
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Nail in washer
Hi I had the same problem, but not a nail a bra under wire, they have a wire that is sown in under the cup these often work loose and slip through the holes in the drum,in my case it was catching on the heating element if not removed it would catch the element and even damage it or at best my a bad noise. To get at it i just undid the heater element pulled it out from the drum and this then gave me good access to the drum housing so i was able to get at the wire. You must make sure you unplug the washer from the electrics DO NOT work on any appliance when it is connected to the mains. All washers have an heater at the bottom of the drum.If you are handy it will not take you more than an hour to do this job.Good luck.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bra wire gone inside drum!!!!!!
you will have to open the bottom of the unit there is a pump clean out and a hose to the tub you maybe able to get it from there REMOVING the tub is not an option at this point
PS: have some towels handy to catch the water
Jan 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
How to remove Bra wire trapped between drums.
Try to see if there is a large rubber sleeve underneath that you can remove. It will probably be fastened with a clamp. Make very sure that you get it tightened afterwards, or it may leak.
Dec 05, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
