Question about Maytag M7DH45B2A Dehumidifier
I connected the hose adapter so that I can drain directly into the sink. But it still drains into the bucket. Did I miss a step?
  • hottrocker Jul 06, 2010
    This sink IS lower. The problem is that the part where the adapter is connected does NOT port water. IT comes out of another location.
I had the same problem. The plastic tube that routes the water out the back doesn't fit tightly. It took a couple of weeks but the bucket would fill and the darn thing would shut off.
My first attempt was to put a hose clamp over the adapter. The clamp was simple enough but then the bucket wouldn't go back in. Using a small saw, I carefully cut a notch in the bucket. WARNING: Make sure that whatever you cut doesn't reach low enough that when the bucket fills, the little float thingy shuts off the unit before it starts to leak. Anyway, that still leaked. The problem is that that plastic tube is stiff and slippery and doesn't seal well.
What finally worked for me was to take the adapter off, go to the hardware store and buy some clear plastic tubing. I found some that fit very tightly over the tube inside and, with the hose clamp, sealed well.
Problem solved.
Posted on Jul 30, 2010
  • 1,557 Answers
The water is not pumped it is gravity feed so unless the sink is lower than the unit it will bypass over the adaptor and into the fill bucket
Posted on Jul 03, 2010
Model DM32M Haier Dehumidifier. I am missing a part which diverts the water into the hose drain. All the water now goes directly into the bucket. I want it to drain into the sink nearby.
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 22, 2017 | Haier Dehumidifiers
Why would the system keep running, all the time, filling up bucket, then leaking onto floor? What is my next step?
There is supposed to be an auto-shutoff float in the bucket to prevent overfilling of the bucket. You have either removed it or it is defective. The fact that it runs constantly has more to do with the humidity and the setting that you have the unit set to, Obviously there is adequate humidity in the space or the bucket would not fill. You need to look for, find, and repair the shut-off float, or, if possible, some units allow you to connect a drain hose either to the bucket or directly to the unit to drain the water to a drain. If you choose this option, remember that the hose must remain lower than the top of the bucket or it will not drain properly and the bucket will still overflow.
Jan 23, 2016 | Dehumidifiers
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
Dehumidifier manual
Good morning friend, thanks for your post!
Based off what you're explaining it sounds like your Frigidaire dehumidifier might not be leveled. Any time your dehumidifier is not properly leveled water will not drain out the rear but instead into the bucket. I would recommend checking to assure your appliance is leveled. If your dehumidifier is leveled detach the hose to make sure nothing is blocking the water for exiting into the hose. If those steps are unsuccessful and you continue to get water into the bucket please respond back and I can research more information for you. Best of luck. -Matt
Aug 17, 2014 | Dehumidifiers
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
Whirlpool AD50USS Dehumidifier WILL NOT DRAIN THROUGH HOSE
I have a similar model. There are two drains, one for the hose and one directly into the bucket. The hose one is supposed to be lower, but I had to put a 3/8 inch block under the right side of the unit to get the water to favor the hose instead of the bucket. Another possibility is that the far end of the hose is higher than the near end. If you can't lower it, you can put the whole dehumidifier up on blocks. One other thing to check is that the hose has a rubber washer in it where it connects to the unit. Use a tissue to see if this connection is dry. If it leaks, it will just drip into the bucket.
Jun 04, 2012 | Whirlpool AD50USS Dehumidifier
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Mar 21, 2011 | Whirlpool AD35USS Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
369 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
