Question about Thetford Norcold RV Cooler/Freezer
Norcold rv cooler freezer H fault code comes up on display. what does it mean?
  • 62 Answers
SOURCE: i have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Posted on Jul 22, 2009
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
SOURCE: Norcold R.V. Frig / freezer not cooling
I have the same problem and I'm not going to pay 500 dollars to get it fixed. That's why i go to these forums.
Posted on Nov 07, 2008
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Posted on Jan 29, 2010
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
Why does amana frostfree refrigerator ice up when you overload the freezer?
sounds like the airflow is being block by the overload of product. No air flow means a frozen coil.
Jun 06, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
While working on ac switches to lp with no warning.
If the incoming AC voltage falls too low, it does this to maintain cooling capacity. It will also do the same thing if voltage gets too high.
It might also indicate that the control board is detecting a problem with the heater element. Are there any faults or check lights being displayed after it switches to gas?
Jun 23, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold rv cooler code needs reset reading no co
u need to take into dealership or have a tech reset the board if not done right u can blow your board out
Sep 19, 2009 | Thetford Norcold RV Cooler/Freezer
Fault code on norcold refer model 640.3 reads "no" "co",how do I reset
u must take into a dealer or have a mobile tech to reset the board
Jul 29, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
850 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
