Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Turns on but no picture stand/by with timer light blink about 5 times
cyberclash
  • 6 Answers
SOURCE: blinking stand by light
the cause of your problem is in the crt socket your tube may be weak.try to adjust the g2
Posted on Jun 25, 2007
ladywinn
  • 5138 Answers
SOURCE: 2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
Posted on May 19, 2008
rulds2008
  • 3866 Answers
SOURCE: tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Posted on May 25, 2009
SOURCE: 65" Sony Sound / No picture 10 & 5 blinks on timer/stand by light
I had the same problem on the 57inch model of this TV set. Thankfully, it has been fixed at a reasonable cost! The fault was definitely caused by the IC's (two identical ones on the D board). They are marked MCZ3001DA. The replacement part (upgrade) is MCZ3001DB. I bought a number of them online (cheapest I found was about $25 per pair, and cheaper per IC if you buy more) and had an experienced TV repairman replaced for $100 (he originally "diagnosed" the cause - just by confirming the 10 blinks frequency I told him before he first visited). I guess he had seen this issue a lot before. He had it up and running within 45mins. It has been working fine since (4 days now). I am very pleased with the outcome so far. Hope this helps.
Posted on Jun 05, 2009
SOURCE: Stand by light flashes 5 times
It seems to be that you ballast is losing its energy, that means it can't keep up with your lamp, because it's one in charge of lighting up the bulb so the image can be projected on your screen. You will need to replace it to solve this issue. Hope this is some help for you. :)
Posted on Jun 29, 2009
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Sep 16, 2009 | Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Tv turns on then off, stand by timer light blinks 4 times
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
261 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
