Question about LG 32LC2D Television
My LG32 LF7700 cant seem to obtain any channels regardless of being plugged into the aerial that goes on the roof.
  • 1,557 Answers
It would seem the uhf/vhf receiver has burned out try hooking up a digital set top box to it if you dont have any luck email me and we will find a soultion
Posted on Jul 03, 2010
No dvb signal on Vierra Panasonic tv
If the tvs share the aerial but only one is working then the wiring of the non functioning socket has shorted. Perhaps the cable you used to connect the second set is damaged,try another. PERHAPS THE AERIAL SOCKET HAS BECOME DAMAGED,THIS ONLY COSTS A FEW PONDS/DOLLARS TO CHANGE. Alternatively it might be the wiring from the roof to the wall socket that is faulty.
First things first, check that the tv is working by connecting it in the other room. If it does work there you will know that theaerial socket in the second room is faulty and can begin testing.
Jun 03, 2015 | Panasonic Televison & Video
We use to get antenna on our tv now we cant n use to get analog n cant what can i do
analog tv has been turned off and is no longer available. if you have not got a digital aerial on you roof you will have to get an indoor digital aerial. if you have a sky dish and receiver you can plug that into the tv and watch the free channels.
May 21, 2015 | Televison & Video
Shall I buy signal booster? signal 23 bit error 3 but only BBC channels affected. Picture keeps breaking up
how old is your aerial and cables. and were is your aerial located loft or wall etc. in loft would buy one if roof may be a bent out aerial or heated cable from the sun. if you have been fine with the signal from the 28th of june till now would say arial problem or cable.
Oct 02, 2013 | Televison & Video
Why are roof tiles, under TV aerials, discoloured on most roofs?
Most of the discolouration I see has got nothing to do with the metal, which is usually a fairly inert aluminium covered in aluminium oxide. What does seem to happen quite a lot is birds sit on the aerials and just do what comes naturally - leaving behind a bit of a stain. I spent a few years at sea and saw an albatross roost on a rotating radar aerial overnight. The next morning the deck underneath was a mess of semi-digested fish, a huge amount for just one bird! Here you will get more information about aerials.
Oct 16, 2012 | Acer Aspire AS5334-2153 Notebook PC
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Cant pickup chanels on TV when doing scan. Have the Flat panel lcd in sundowner trailer and its suppose to be hooked to antenma ontop of the trailer but I can't get any channels even after scanning several...
I would try scanning for channels when tv is hooked up to your house main aerial or a portable aerial. If it does pick up channels, the tv is not at fault but instead your aerial ontop of trailer. If this is the case, check your aerial plug. If the plug is moulded on it may be broken inside, or if it is a fixable plug, check that the outer coax shielding is not touching the centre core inside the plug.
Mar 17, 2010 | Jensen Televison & Video
I've purchased Plexgear DVB-T stick and installed corresponding software, but when scanning channels have no result. That would be nice if somebody can help me in this matter.
If you are trying to use the ariel that is supplied with the unit you will never find any channels unless your house is next door to the transmitter. You will need to connect to your normal roof ariel.
Nov 03, 2009 | Computers & Internet
New aerial wont pick up digital reception and fuzzy picture on terrestrial channels
Hi.
If you put aerial up your self was it wide band aerial ?
Is it in the atic or on the roof ?
Have you used decent quality cable (not the cheap stuff)
How long is cable run from aerial ?
Have you checked that when you fitted rf plugs that none of the braid strands are touching solid copper inner core ?
Ask an earial installer or Tv shop what the signal strength is like in your area.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Televison & Video
PS2
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Jan 06, 2008 | Televison & Video
Televison & Video Logo
94 people viewed this question
Computer Repairing
Computer Repairing
