Question about HP LaserJet 4250n Printer
All control panel light on. nothing on the screen. can't print
    Novelist:
  • 170 Answers
Make sure that all of the buttons on the control panel are not stuck in the in position, other then that this usually will indicate that the logic of the formatter has been damaged and the formatter will need to be replaced... They are a snap to install, just 2 screws hold it to the machine then you would slide it back until it disengages from the machine. If you do end up needing one you can get one pretty reasonable here: Click here for formatter with network card built in
and Click Here for formatter without a built in network card
hope this helps and if so please mark this a FIXYA...
Posted on Jul 05, 2010
Samsung ml-2580n don't recognized bu USB after resetting firmware. green light just flash,nothing works. can somebody tell me a problem?
Maybe you have the same printer installed more than once. If that's the case the computer gets confused and so do you because you can be printing to the one that is not active or online. Only one can be active or online at a time. Click Start/Control Panel or Start/Settings/Control Panel and click on Printers to open it. If your printer is listed more than once, Right Click on it and select Delete.
Also look down at the bottom right near the time and if you see the printer icon click it to open it. If there are documents in the print queue waiting to print, cancel or delete them.
Now you should be able to print.
Jun 04, 2012 | Samsung Office Equipment & Supplies
Green light is on - when select print nothing happens - print queue shows printer not responding
go to control panel then choose printer the set the printer model you are using to default then try to print again or check the cable if properly connected and lastly re install the driver if needed
May 21, 2011 | Computers & Internet
I turned off the printer before it finished printing. Now the light keeps flashing but nothing prints.
cancel the printing... on control panel double click the printer.... double click the model of your printer to display pending printing process.. then cancel print.
May 17, 2010 | HP DeskJet 970cse InkJet Printer
My ricoh ft4530 control panel does not display anything and no light when turn ON. Power is OK
1st try the adjustment knob on left side of control panel. still nothing it could be a bad lcd screen or power board to the lcd screen
Apr 16, 2010 | Ricoh FT5832 Copier
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Printing problems
plz check whether the driver is installed, go to printers on control panel and try for a test page print, if test is printed, then could be ur software is looking that printer.
Aug 18, 2008 | ASUS Eee 4G Notebook
Not printing
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
HP LaserJet 4250n Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
