Question about Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
Hi I have the hayward 1.5hp I started the pool and it was running good but all a sudden it's making a stange noise for a few second before it start and it will shut off by itself.Could be because it was running for a long time to clear the water.Thank you John
  • 3,600 Answers
Are you sure it was pumping water when you started it? and did you prime the pump before starting it up? if not prime the pump first.
Posted on Jul 03, 2010
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
When the motor/pump is powered on sometimes it makes a humming noise ans after a few seconds it sets the breakers off. If I manually attempt this a couple of times the pump starts up OK. This does not...
Your motor is covered under a 1 year manufacturers warranty. The issue you describe can be one of a couple problems all of which will lead to permanent motor failure if not corrected. I'd suggest you go back to the place of purchase or contact AOSmith for a warranty center near you.
You can find the warranty center online at:
http://www.aosmithmotors.com/AOSECatalog/ServiceshopLocator/ServiceShopLocator.aspx
John
Jun 28, 2011 | Hayward 2hp Pool Pump Motor A O Smith...
The pump is slow to start. It cranks for a few seconds before running at full speed. sometimes, after cranking for a few seconds, it shuts off. The unit is 10 years old.
HAVE THE START CAPACITOR CHECKED, SEARCH YOUR AREA FOR FREE POOL PUMP MOTOR TESTING, OR BUY A NEW CAP IT SHOULD BE A 161 @ 110 VOLTS.. OR.. THE START SWITCH MAY NEED TO BE SET OR IS WORN AND NEED TO BE REPLACED. LOOK ON EBAY FOR A START SWITCH. YOU MIGHT BE ABLE TO TIGHTEN THE 1/4 SCREW 1 TURN THAT HOLDS THE START SWITCH, THIS JUST MIGHT SOLVE THE PROBLEM
May 28, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
May 14, 2010 | Hayward Pool Products Hayward Super II...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a clicking noise coming from the new Hayward super pump.
Is the motor running? It will make an audible 'click' when it turns on and another as it slows to a stop once shut off. If it keeps doing it during the run time, you are likely not feeding it the correct voltage. Otherwise, one click at the start and end is normal.
If the motor is set for the correct voltage and the line voltage is ok, the motor is starting to fail and will need service at a local electric motor repair shop.
Jul 12, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
293 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
