Question about Dometic Refrigerators
When turned on , whithin 5 minutes on either a/c or gas the check light comes on, and it does not get cold.
  • dsfrench65 Jul 03, 2010
    off to get my parts will let you know.
    President:
  • 1,197 Answers
This is a common problem with, Dometic RM2807 or RM2811 and most latermodel Dometics with upper controls. The refrigerator's "check light"comes on or the refrigerator just shuts down seemingly for no reason.Another common problem occurs while on 120v. The refrigerator mightswitch to gas or just shut down even while you have a good 120v supply.
the Dometic RV refrigerators with the push buttonupper control boards have a problem with the main power boards. Thepower board components are encased in yellow epoxy, reducing heattransfer. This gets them to run too hot which in turn canoften cause the power board to fail completely or cause problems suchas listed above. The only effective repair is to replacethe power board. It is not advicable to go for the Dometic replacement as they too canfail. The Dometic replacement also requires you to rewire the board andgas valve. The only board we recommend is the P-711. The P-711 not onlywill fix these problems but does not require the rewiring. It uses allthe standard wiring. See Power Boards
good luck with your fix
Posted on Jul 03, 2010
CWH24A-R Window Air Everything works but no cold air. compressor does not come on
Hello...
are you sure the device warm?
Inside the device is a valve that reverses the direction of gas. If warming means no loss of gas. If not, then the valve is locked .Try lowering the minimum desired temperature in COLD MODE and wait 5 minutes, you should call the warranty because it is still valid.
Aug 10, 2014 | Haier 23,800 BTU Window Air Conditioner...
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
2011 Dodge Grand Caravan - On colder mornings, the car won't start. The security light won't stop blinking and the engine light comes on when I turn the key. If I leave the key in but not turned for a...
check the condition of the key battery as it may be low in cold weather and not communicating properly with the immobiliser.. I suggest this because batteries generally fail more often in cold weather compared to warmer climates.
Oct 23, 2013 | Dodge Grand Caravan Cars & Trucks
Park Avenue Stalls wont crank when warmed up
no its not the fuel pump, filter maybe... cant see why though.
Jul 06, 2012 | 1992 Buick Park Avenue
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a 1992 dodge power ram with a 318 in it. When the weather starts getting cooler in the evenings my truck won't start right away. It will turn over for about 5 minutes with the check engine light not...
I would guess a bad spark plug wire. Moist air will provide a path for the spark to jump to ground from a bad plug wire. You could test with a windex bottle filled with water and spray the engine in different spots. Also check for moisture under the distibutor cap.
Sep 07, 2010 | 1992 Dodge Ram 150 Club Cab
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Whirlpool gas dryer rotates, gas ignites but goes out, won't reig
coils on the gas valve, especially the single coils that whirlpool uses, break down after use. They may ohm out good when cold and the burner may light 1, 2, or 3 times, then you get ignition failure. Coils are bad. Hint when replacing coils. the front coil which has 3 terminals has a metal sleeve inside the coil. Make sure that sleeve stays with the valve. It can get stuck in the old coil and thrown away. Good luck
The Squirrel
Mar 26, 2009 | Dryers
Refrigerators Logo
70 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
