Question about Canon EOS 40D Digital Camera
Sometimes when I depress the shutter nothing happens for several seconds. I have to depress the shutter and the camera finally takes the picture. its does not happen all the time.
    Brigadier General:
  • 11,967 Answers
You need to press the shutter half-way and allow the camera to lock in the focus (it will beep) and then press the rest of the way when the moment is right.
Posted on Jul 03, 2010
How to take sharp pictures
Many people new to digital move too quickly after taking a photo. I usually tell people I teach to count , 1-2. After depressing the shutter button. Often clears up many peoples photos. You can also try bracing the camera against things around you to stop small. Movements as you depress the shutter. Sometimes a walking stick to rest the camera on the top of as you take a photo helps.
Aug 06, 2014 | Panasonic Lumix DMC-ZS30 DMC-TZ40 Digital...
It turns on but won't take a picture when you push the button! I downloaded the pictures on the card because I was told maybe it wouldn't worked due to a full card. It did have 2300+ photos, but only 77...
The shutter button has a little nib on its end that can break off with age. This tiny piece of plastic extension is needed to fully depress the shutter switch inside the camera. There's a fellow on ebay that sells these with instructions (see this link). But sometimes you can get a better deal by buying a broken A520 with other issues, and just cannabalizing this part.
May 09, 2010 | Canon PowerShot A520 Digital Camera
Sometimes it takes a few seconds before my Canon Powershot SX10 IS will take a picture I have button pushed down but it won't take the picture?
Unfortunately that's how the camera is designed.
The camera has to do a number of things before it will take a picture. It has to check the lighting, and focus and make calculations based on those factors about how to set the camera to take the best picture.
It is best practice to get your subject in view. depress the shutter button half way and hold it so it can focus and determine the exposure, and then completely press the button the rest of the way to release the shutter.
Good luck
Oct 27, 2009 | Canon PowerShot SX10 IS Digital Camera
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a nikon d200, lately the shutter lags 1-2 seconds.
It is probably delaying while it autofocuses.  If it is like most Canon cameras, depressing the shutter half-way should allow you to focus without taking a picture, then when the moment is right, depress the shutter button fully to take the shot.  You will want to practice this a bit to get used to it.  Shooting in low-light it can take longer to find the focus, so it becomes more necessary to use this technique.
Hopefully that helps, but I am not a Nikon user.
May 10, 2009 | Nikon D200 Digital Camera With 18-135MM
Very long lag time to shoot and between shots... sometimes!
hello again after researching i did find out that there is about a 3 second delay if using the flash option did any of your delays happen when not using the flash ? also does this happen when using the camera in auto mode ? turning the knob on the top to the green auto mode i'm thinking it also could have to do with your shutter speed or try going to the menu and changing the shutter speed to a faster speed your self then taking pictures in av or tv mode. here's a comment from a review on the PowerShot a590 that might help. Camera performance is very good. The PowerShot A590 is ready to shoot after a 1.2 second delay -- pretty snappy. Focus speeds were very good, even in low light situations. Shutter lag wasn't a problem, and shot-to-shot delays were minimal, except when you're using the flash, which is slow to charge. The camera can shoot continuously at 1.5 frames/second until your (high speed) memory card is full. The A590's battery life is 10% better than its predecessors, and is well above average for its class. The camera supports the USB 2.0 High Speed standard, for fast data transfer to a Mac or PC.
and if you still have the problem with out the flash then the only other solution is a faster flash memory card there's cards made just for digital camera's that store pictures and format quicker.
hope this helps your enjoy your camera.
Apr 04, 2009 | Canon PowerShot A590 IS Digital Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Sony DSC-P72 won't snap a picture
Have you done a "hard" reset?
Under the jack cover (below the zoom rocker on the back of the camera) there is a small "reset" button. You'll need to press it with a sharp object, and hold it down for a few seconds. If it was a setting problem, this should resolve it.
Nov 11, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon EOS 40D Digital Camera Logo
174 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
