Question about JBL CREATURE II Computer Speakers
No power to computer speakers
My dog has chewed through one of my speaker cables and although the cable is fixed I now have no power to them.
  • 1,557 Answers
If the cable is fixed correctly then it would seem when your dog chewed through the cable the cables met and caused a power short out that has blown some of the internal electronics components there fore the unit will not work. taking into consideration the price of jbl creature speakers it would be cheaper to replace the unit than to have repaired ..
i hope this helped
Posted on Jul 03, 2010
Our Bunny chewed thru the wire going from speaker to computer
The speakers are inexpensive. If the wire goes into the back without a plug, it may be easier to buy new speakers. But if you can solder, then the wire can be repaired. There is no voltage in the audio wire so you cant be hurt if you try. Just match color for color if you want to give it a go. This link may help How To Fix Damaged or Broken Audio Cables
Jun 03, 2015 | Dell A215 Computer Speakers
Denon AVR-487 SYS-57HT SPEAKER SYSTEM
check that wire and fuse again and try to reset and try
Dec 11, 2007 | Denon AVR-4800 Receiver
JBL CREATURE II soundspeakers are dead without power
When the power to the system was applied to the speakers before you realized the cables were chewed, you blew some components in the power boards to the speakers. You could look to see if there are replaceable fuses. Otherwise a trip to the repair shop or new speakers.
Apr 08, 2014 | JBL Audio Players & Recorders
Replace bad wires
Unlikely to be bad wires unless the cat, dog or rodents have chewed through them?
The obvious thing is that as wire has come unplugged.
I have been through a number of sets of computer speakers. I now have a pair of Bowers and Wilkins MM1s. The sound is amazing and they are actually repairable and have great warranty.
http://www.bowers-wilkins.net/Speakers/Computer-Speakers/MM-1/products-details.html
Mar 23, 2014 | Harman Kardon HK206 Computer Speakers
I have a sound problem with my montgomery ward sentry sound bar , when its connected to to my tv and work great then i unpluged it moved it put back together its doesn't have sound?
Could be an internal effected by disconnecting when the sound bar when the power was still on. Always remove or connect speakers or other electronic devices at power-down (not active) as transient current can damage sensitive electronics. Check you wires, cables, and in/out ports for defects or dirty posts, etc. Perhaps the dog or cat chewed on the lines....never know.
Jan 10, 2014 | Montgomery Ward Sentry Sound Bar
Need to replace th 5 pin DIN plug on harmon kardon sounds stick 2- dog chewed thru it and the plug is gone!
If the mentioned cable is the one that is connected to the motherboard of the sub woofer and has two connectors for the speakers on the other side - please contact the Harman/Kardon support of your country, as they may be able to replace this part (actually this is a very rare part) it also may occur that the company will not be able to replace the part with a genuine one, but with a modified one. You can also try to contact some companies that would be able to replace this cable with a custom-made one.
Dec 25, 2013 | Harman Kardon SoundSticks II Computer...
I was whatching my daughters dog while she was away on business at my home. some how some way he managed to chew off the yellow connector plug for the speaker and chewed it up beyound use, as well as chew...
I was able to catch a glimpse of the back of this unit. I cannot tell by the picture but it is either a RJ11 connector or RJ45 Connector. RJ 11 is the connector on your landline phones and RJ45 connectors are used in computer networking applications. If you have either of these cable laying around you can verify which is which, after that if you do not want to buy the crimp tool for these connectors I would suggest sacrifice whichever cable it ends up being (RJ11 or RJ45) and splice your speaker wire to the two active leads, + and -. Good luck!
Jul 19, 2011 | Durabrand STS98RW Theater System
Dog chewed through wires to the sub
It should work. Make sure that the joints are soldered and properly insulated
Apr 20, 2010 | Dell 5650 Computer Speakers
I need a cable
Which cable did the dog chew on? I looked on sony's web site you can buy it direct from them. If its a common cable I suggest www.cyberguys.com
Jan 08, 2008 | Sony SRS-D5100 Computer Speakers
No sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Jan 05, 2008 | Altec Lansing ACS 45.1 Computer Speakers
JBL CREATURE II Computer Speakers Logo
227 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
