Question about ViewSonic E50C 15" CRT Monitor
The brightness/contrast window pop up randomly and frequently. Brightness level keep on increasing automatically. Pls help.
    Brigadier General:
  • 10,406 Answers
A 15-inch CRT monitor? It's time to responsibly recycle it, and buy a 17-inch LCD monitor, because _nobody_ fixes CRT monitors any more.
Posted on Jul 04, 2010
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Lost its brightness and clarity
Hello
Check whether the backlights get full brightness as you increase the bright ness level. Set the set to least contrast level, and check whether the backlight is sorking well. If it is OK, then try to increase the contrast level [to at least 70% of the total]. If backlight level cannot be adjusted according to the contrast level the backlight inverter baord and backlight CCFL lamps need to be checked.
images of the backlight inverter board and CCFL lamps are attached here.
Feb 21, 2012 | Toshiba 42HP66 42 in. LCD Television
I have one pro view 17" view sonic monitor CRT with win xp as my OS. when i am working in my computer suddenly the contrast and brightness symbol comes on the screen and begin to increase to maximum...
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
Jan 18, 2011 | ViewSonic E70fb 17" CRT Monitor
Sir iave an IBM desktop and the monitor windows
Press Fn+F5 to decrease brigtness Fn+F6 to increase brightness
Try this please.
Jul 05, 2010 | IBM E74 17" CRT Monitor
Brightness contrast pop problem
one of the buttons will have dust in it causing it to trigger randomly or it is faulty take it apart and replace the buttons, make sure you do all otherwise it will still do it the work on impedence and they are all in series
May 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Oct 02, 2009 | Proview PL19Wb Monitor
How can I adjust the contrast on my laptop, I can't see very well
Hold the Fn key down, then press the Right Side Arrow key to increase brightness. (Bottom of keyboard, 5th key from the right)
Granted, that doesn't increase the contrast, it increases the Brightness.
Should the brightness not increase to a level that you feel is comfortable, then I suggest you have a Backlight, or Inverter going bad.
Sep 14, 2009 | Aspire Acer 7520-5071 Notebook
ViewSonic E50C 15" CRT Monitor Logo
535 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
