Question about NEC PXT-50XD2 50 in. Plasma TV
Every 2 hrs aproximately the tv just turns off. I have to turn the power off at the power switch on side of tv then turn it back on and it works for up to another 2 hrs and off again, etc any ideas on what the cause is and approximate cost to have it repaired? Thanks deb
  • 1,056 Answers
Buy one of those spray from radio shack or other electronic store. It comes in a can and sprays cold gas to cool electronic components. Open the TV and see which of the aluminum heats sink gets the hottest. Spray the can on the suspected one. Once you find out which one it is. You can carefully add more aluminum heatsink so it will dissipate more heat and prevent shut off. You may have to rig up some screws and nuts. you would need to position the additional heat sink in such a way that it wont touch any live components. I have worked on an HDTV with the same problem and it worked great. The aluminum heat sink are there to dissipate heat from semiconnductor device but sometimes the design is flawed by not having enough surface area to dissipate heat or it have just the exact surface area and not enough room for slight increase in temp. Sometimes component value changes slightly causing the circuit to work slightly harder but not enough to cause an immidiate shutdown. Adding more heatsink to the suspected cause of shut down to let it work slightly cooler is probably the best solution.
Posted on Jul 03, 2010
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
SCREEN doesn't turn on when powered up
it's the power board (transformer). Buy on ebay for 99.00 and replace.
Jul 03, 2009 | Polaroid Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Not connecting to tv
If you changed the video output settings when you connected to another tv then you will have to reset it.Switch the ps3 on and hold the power button until it has beeped three times(not including the first power on beep).This should open a menu,choose option 2,this will revert your system back to default settings.Hope this helps
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Tv will not turn on
A: Is there a humming sound coming from the TV set?
Check the brightness/contrast. If nothing still, remove power to the set for 24 hrs. and reconnect and retry. If it's not coming back up, the PCB ("motherboard") for the set has most likely died. Check for warranty information in your user's manual for further instructions.
B: Is the TV sharing an electrical line with a wall switch?
Remove the set from that circuit and try another outlet. If not, follow the Steps for "A".
C: Was it during a power storm, when it went blank?
Check the outlet with another appliance - if that device works, try the Steps in "A".
Nov 28, 2008 | Philips Magnavox 27MS343S 27" TV
Tv shutting off on its own.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
NEC PXT-50XD2 50 in. Plasma TV Logo
44 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
