Question about Kenmore Dryers
I have a kenmore 80 series dryer electric when i push the start button nothing happens the one thing i hear is a clicking sound coming from the timer i already changed the motor that didn't work
    President:
  • 1,554 Answers
Kenmore dryers usually have a thermal fuse mounted along side with a cycling thermostat on the blower housing. The thermal fuse is wired in series with the motor circuit and its failure leads to the dryer not running.
Remove the rear panel to access the thermal fuse and bypass it. Replace the thermal fuse if the dryer runs indicating that it has failed. The cycling thermostat must also be replaced because it is the sole reason the thermal fuse fails. The thermal fuse fails when the cycling thermostat fails to cycle and regulate the dryer temperature.
Indicate the exact model number of the dryer if the advice provided is not applicable, does not work, or if you need further assistance. You don't have to accept, reject, or rate this advice to post additional information or follow-up questions.
Posted on Jul 03, 2010
  • brunohagar Jul 03, 2010
    it wasn't the thermal fuse
  • Jahn27
    Jahn27 Jul 03, 2010
    The motor is good for sure and so the thermal fuse. Attention now should be focused on the timer, start button, and the wring. Make sure that power is being supplied to the dryer. Please give me the exact model number as requested for me to proceed with more accurate and further troubleshooting.
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
