Question about Lexmark X2500 All-In-One Printer
Lexmark Printer Install - No Communication Error
So I got this new printer, a nice Lexmark X5495 all-in-one, fax, scan, copy, photos, prints, all the bells & whistles, right? I install it step by step just like it tells me to do. Everything shows fine, all appears hunky dory. Go to control panel, it says ready, big happy checkmark, it's set as default printer, it's online. Just one problem, it won't print. I get this nasty message that says there's no communication between the computer and printer. I tried 3 different USB cables. I unplugged, restarted, rebooted, tried every USB port on my puter, no go. Same thing. I checked windows firewall, the Lexmark stuff is all checked as exceptions, meaning they are being allowed through. I deleted the other 2 printers from the system. I uninstalled the new printer and reinstalled it - 5 times. I just have the feeling it's something in where the USB cable is hooked up. I have 4 USB ports in the back of the puter. I have 3 in front. All the troubleshooters tell me to check the USB connections and cables, then restart. No go. Same thing. I have Windows XP Home. I have listed this problem under Lexmark X5470 cause the 5495 wasn't listed.
I've been at it for 5 hours now. I know it's something simple and stupid, but that's me - simple and stupid. Any ideas?
i am receiving the same message My printer is not communicating with my computer. control panel indicates it is on online and ready. I have disconnected, reconnected several times. What am I to do.
  • 12 more comments
  • mityguy23 Apr 21, 2008
    i bought the lexmark x2500 series printer and it is having comunication error with my computer, and i also bought a new usb cable and have done the restart, and also having isses witht the firewall now going crazy
  • Anonymous Jun 17, 2008
    Communication error
  • Anonymous Jun 21, 2008
    the cd has been placed in the cd drive and we have tried to install the printer by going to the start menu selecting run. After that it will not do anything after that point.
    The cd has been placed in the cd drive and we went to the start menu and selected the run option. Nothing happens after that point.
  • billmoo Jul 10, 2008
    Have done all the same things as babe,please come up with a solution.
  • blondebuster Aug 16, 2008
    lexmark is a piece of ****
  • raffo1 Sep 21, 2008
    Same problem -8 wasted hours uninstalling and re installing. Am now even having to restore my system back just to get my cable and wireless modem to be recognised.
  • tswheeler5 Sep 22, 2008
    I have the same problem with the Lexmark 4850. It was printing for 4 months and then just stopped printing. I can't print wirelessly anymore. I have done everything on the list and nothing helps.
  • ahiu Oct 07, 2008
    same pronlenm as the first guy it seems like my computer isnt finding the new software I have the disk but that is not helping me I have been at it for 3 days PPPPPPLLLLLLLEASEEEEE HHHHHHEEEEEELLLLPPPPP!!!!!!!!!!!!!!
  • shy953 Nov 30, 2008
    i have the same problem and im mad cause i really need to print this stuff byt try to get the cd that came with it and intall it
  • Anonymous Feb 02, 2009
    Frustratubg problem!
  • Anonymous Feb 25, 2009
    lexmark printer X5495 is not communication with computer we have everything on the computer. we have no disc to install
  • raffo1 Mar 02, 2009
    I have the same issue of no communication with the X5495 -basically I now have a big paperweight which will photocopy,print from usb stick but simply wont print from the computer. I have tried all the suggestions listed but no result. I also have the unusual problem of having to use "go back" every time I try to install it. It completely disables my pc every time. After installation the start menu freezes and nothing works at all. The only way to get the pc working again is to start in safe mode and use windows restore to get going again.
  • Anonymous May 07, 2009
    I am having the exact same problem.
    Sergeant:
  • 237 Answers
Is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Posted on Jun 25, 2008
  • gary433 Jun 25, 2008
    Courtesy of Microsoft...
    This issue may occur if Windows turns off the power to the Universal Serial Bus (USB) Root Hub device to save power.
    RESOLUTION
    loadTOCNode(1, 'resolution');
    To resolve this issue, follow these steps:
    1.
    Click Start, right-click My Computer, and then click Properties.
    2.
    Click the Hardware tab, and then click Device Manager.
    3.
    Expand Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties.
    Note There may be more than one USB Root Hub installed in your computer. In this case, you may have to follow these steps with each USB Root Hub device.
    4.
    Click the Power Management tab, click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
    5.
    Quit Device Manager.
    May need to reboot
  • 3 Answers
Download the 64 bit version of the driver even thought you have a 32 bit operating system. there's a problem with lexmark's 32 bit driver for the X5495
Posted on Feb 03, 2009
We purchased a Lexmark x5495 two days ago. DH set it up; it worked for a full 10 minutes. Even printed from Word. Then poof! Trouble communicating with the printer. DH tried (almost) everything, including an online session with Lexmark. Still no communication.
What DH did: Uninstalled all drivers and printer. Used computer tweezers to reshape USB connection IN THE LEXMARK to fit snug with the USB cable connection. Then he reinstalled printer USING WINDOWS XP ADD PRINTER WIZARD (wizard allows naming USB port to use). Poof! My computer now communicates with the printer!
Posted on Feb 18, 2009
I dont see any exclamation points on any hardware componets, any thing els else i need to check
Posted on Apr 21, 2008
After a days worth of attempting various methods to fix the issue. Ive finally come up with an answer. Lexmark Tech support is terrible.
If you're getting communication errors, you need to full reset the PRINTER and COMPUTER to factory settings and set it up fresh. This means you need to reset every setting on the printers control panel (thats physically on the printer, not in windows) to the factory settings.
Reset to factory
Unplug the printer
Uninstall all instances of lexmark software and drivers
Uninstall any third party scanning software
Restart the computer
For wireless networks, this means changing your WEP key as well. Just to make sure the printers settings have not been stored.
Now plug the printer back in
Run the software setup. And choose setup like its your first time. Youll need your USB cable to correctly set it back up. So get that out.
Follow the prompts of the software. Make sure you get to enter the new WEP key into the lexmark setup wizard.
When the lexmark installer completes, install any third party scanning software that you are using to scan. It should be able to fully communicate with the AIO (all in one) printer now.
Posted on Sep 18, 2009
  • 323 Answers
Here's what I would advise.
Go to your device manager.
Right click "my computer" on your desktop.
Click on "properties"
Click on the "hardware" tab.
Click on "Device Manager"
Click on "Universal Serial Bus Controllers"
After it's highlighted, right click on it and go to "scan for hardware changes"
Click on each individual + sign after you do this and make sure you don't have any exclamation points on any of the hardware components.
Let me know if this isn't clear enough, okay?
SOURCE: Lexmark Printer Install - No Communication Error
Hi, Maybe you can reload windows XP drivers. from this site: Photo Paper (Letter - 20) -- Lexmark United States Good Luck
Posted on Jan 15, 2008
I had the same problem with a X5470 and fought it for a couple of hours. I installed and reinstalled the software, tried different USB cables and ports, etc. It would print OK from the front panel, but no communication with computer. On a whim, I disabled Norton Virus protection and it started working. When Norton was re-enabled, it wouldn't print again. Obviously some conflict with the two, but I still haven't figured out a better workaround yet.
Posted on Feb 24, 2008
rjwharris
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
mamun97
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
866
Posted on Mar 02, 2009
  • 16 Answers
1st -make sure that the USB cable is connected on the correct port of your printer - you might be plugging it on the ports of the telephone - you got 3 ports there - 2 for the telephone ports and 1 for the USB
2nd- check your service if print spooler and lx devices are started (lexbce or lxdcu) - if not.... start it
>start >run>type services.msc > enter
3rd- if still no go - uninstall your driver and download windows vista x64 printer driver on their website
Posted on Aug 17, 2009
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
Lexmark X5495 won't print of fax
There is an update to the driver available issued Feb 2009. You can go to
http://downloads.lexmark.com/perl/downloads/downloads.cgi
to download it and install. You might also check the site for the latest user manual.
As far as overseas faxes, you dial as if you are dialing long distance on any phone.
Apr 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
Lost the cd how to install printer to comp again?
plz check the manufacture website for the driver download
Jan 13, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
LexmarkX5495 won't scan....can you help?
go to www.isohunt.com and download driver detective with key. Install driver detective. And let it to search for the drivers your system needs to operate any hardware. When it searches the drivers for your MFP then install it.
cheers
Dec 07, 2008 | Lexmark X5495 Printer
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Jan 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
5,126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
