Not draining and e2 falut
  • 1,557 Answers
E2 fault . drain motor pump not working - replace water pump ..
Posted on Jul 03, 2010
Telemann model xqb60-803clps. Why is it displaying E2?
From what I've been able to find on the net, the E2 error code means there is a problem with the drain pump. Is your machine draining properly or is there water left in the tub? The drain pump might be partially clogged and taking too long to drain out the water--start there first.
Nov 05, 2015 | Washing Machines
My usb ca-101 cannot detect in my pc
1:This falut Is Your data Cable.
2:This falut is Your Mobile Deta Cable port.
Aug 08, 2012 | Samsung GT S3850 Corby II
Memory card not working
1:This Falut Is Your Mobile Memory Card:
2:This Falut is Mobile Phone.
Jul 31, 2012 | Nokia 6120 classic Cellular Phone
UNMOUNTABLE_BOOT_VOLUME
First Option: Please Update it Sound Software
Second Option:please Take A new Window and install Drivers
Third Option: This Falut Is Cd Room
Fourth Option:This Falut Is Hard.
Jul 30, 2012 | Gateway Computers & Internet
How do i insert a memory card into my INQ clould touchphone?
1:Its Falut Your Memory Card please Change Your Memory Card.
2:It Falut Your Tuch Phone Please Change The Phone/
Jul 29, 2012 | Cell Phones
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
I have gas in my oil. So I drained it all out and refilled the oil. It seems ok now but what caused this to happen?
You could have a falutly gasket. If you are handy and can take it apart, you may be able to repair it yourself. If not, you should contact the manufacturer and see if they'll warranty the repair.
Hope this helps.
Apr 13, 2010 | Craftsman Garden
Error E2
It is drain pum error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Good Luck
Jan 08, 2009 | Washing Machines
Damaged screen
Try a hard reset and if that doesn't work, drain your battery then recharge it. if that doesn't work than you'll just have to deal with it. I have a Palm Tungsten E2 and it has the same problem
Jun 28, 2008 | Palm Tungsten E2 Handheld
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
