Question about Microsoft Windows 98 for PC
Ther is no sound to my speaker i cant see below the window
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 130 Answers
Well this might happened due to some reason first you check below points:
1) speaker should be properly connected to your PC.
2) In your operating system, sound must not be muted.
3) if above 2 points are ok then now you need to check that sound drive is installed or not. you can go to control panel then device manager and that weather sound driver is installed or not. if it is not installed then you go online and search for the sound drive.. thats all then your problem will get solved.
Posted on Jul 03, 2010
I have a sony vgc-rb50 model desktop that had xp i put windows 7 on it and cant here any music or sounds ..
You would need to re-install the audio driver for your sound card but I've check the Sony Website (link below) and their doesn't appear to be any drivers for Windows 7 for your model.
http://esupport.sony.com/perl/swu-list.pl?mdl=VGCRB50
You could try using the Windows XP or Vista Drivers but I expect they won't work.
You only option would be to purchase and Install another Sound Card that. Probably best looking on eBay, but make sure it's Windows 7 compatible.
Please leave feedback.
Cheers
Andy
May 29, 2011 | Sony Speaker
I cant play music or nothing thers no sound on the laptop and i dont no wa speakers i shoulkd get
double check if the volume is on mute there is a certain icon from your keyboard that indicate volume. try holding Fn key then press that volume button to unmute it. make sure also that ther eare no headphone connected as it will disable sound if you are expecting it from speakers. you may also try checking the driver status if you need to reinstall it or update it. simply go to control panel > system > hardware tab > device manager to check audio device there, if the icon has yellow marking on it then that is the problem you just need to reinstall or update the driver for audio by either using the driver disc that came with the system or downloading it from the manufaturers website
Feb 25, 2011 | Lenovo ThinkPad X60 Tablet PC
Cant get any sound out of speakers and everything is connected
Hi, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open, and click on the "Manage Sound Devices." The Sound window will open; click on the "Playback" button, there should be a Speakers Icon, click on it, look below to find the "Properties button, click to open the next window. In the next window there will be (4) four buttons "General, Level... First click on the "General" button, in the top of the window there will be a "Driver" button, click on that button to open. Select to "Update Driver," just click on it, the Drivers will be updated for you. Next you can go back and press the other areas, Speaker Level etc... Next if you have a "MIC" do the same for the Microphone as you done for (Speakers) in the [Recording] category. Note: "Remember to click on the "Apply and OK buttons afterward to make sure the changes take effect. "Restart the computer to finalize the changes." "Rate the solution on it helpfulness, its away of letting me know if you resolved the the problem or you need further assistance, thank you."
Sep 30, 2010 | Dell AX210 2 Speakers
No sound
Test on the audio output amp for a tone, check on speakers, if there is a tone you have a front end fault which could be the audio processor. If ther is no sound connect from the audio output to an amplifier for an output.Then you are lucky.... Hope it works.
Jul 01, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
My b&K avr 507, 5yrs old has just had its R front channel speaker
loose connections. tap on the unit to see if it sputters back on.cant be shorted parts otherwise ther would be no sound at all.and ther is no seperate fuse for each channel.hence it is loose connections on the affected channel.
Feb 17, 2010 | Audio Players & Recorders
Speakers are hooked up, cant listen to anything.
ok the first thing u have to check in ur windows xp desktop that the volume icon is diplaying in the bar below the screen .if not than go to controlpanel --> sound and audio devices --> place volume icon in the taskbar check this option and the volume icon will be avaliable on ur desktop.remember this option is only avaliable if the drivers is installed . than u can double click this icon and set the equilizer. if ur sound not installed than u have to install it from the motherboard cd that is provided by the manufacturer. thankx and take care of urself.
Jun 09, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Cant hear any sounds
Your sound driver is corrupted or removed from your system.Try to re-install your sound driver and then try.
also scan your system with some antivirus.
Thanks
Mar 27, 2009 | Acer Aspire 6930-6771 Laptop
Cant get any sound from my pc..check all val. contrls and ther ok
If you use PCI sound card, you can try to change another PCI slot. Delete sound card in device manager. Scan device to see if system can find the sound card.
Jan 31, 2009 | E-Machines (T2958) PC Desktop
Repalcement Logitech Z5500 Control Center?
My Control center turns on but i can get any sound not even from the test system, Logitech cant help.
I went the a shop and check it on ther system still no sound :(
any ideas
Nov 17, 2008 | Logitech Z-5500 Computer Speakers
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
