Question about HP LaserJet 2840 All-In-One Printer
Scanner Error 6
What is the "Scanner Error 6" messege mean and how do I solve the issue?
Thanks
Roger
Clean glass. switch off. clean the lightsource bulb. keep fingers off the glass when cleaning
Posted on Apr 17, 2008
I have HP Laserjet 3055 All In One. Got Scanner Error 6.
I fixed by going to Device Manager, Imaging Device, uninstalling HP device driver, turning computer off, turn off printer and unplug usb from comp. turn computer back on. plug in usb printer cable to computer, turn printer on, let it search for device driver. Will install device driver for you. Fixed mine. I had unplugged it for a bit while rearranging my office, must have corrupted driver somehow. :>)
Posted on Apr 27, 2014
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Scanner failure messege.
I put new bulbs my printer for the same error message, 2 bulbs with freight cost me $49.00. Now instead of error message after 10 or so minutes, it almost immediate. The tech folks in California says 95% of the time the bulbs fix this issue, but when it does not, it is the "board" at a cost of about $90.00. HP 7110 must have this issue and junk is my opinion at this time. Let me know how you come out.
Jan 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP LaserJet 2840 All-In-One Printer Logo
252 people viewed this question
Seeker5211
Seeker5211
