Question about Karcher Garden
My Karcher K730 MXS pressure washer was leaking water out of the rear of the gun handle. I bought a replacement hand gun and the new gun is doing exactly the same!
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 174 Answers
SOURCE: Karcher B302 gun leaking = taken gun apart but I
jeane_m I can e-mail you a diagram. Can you e-mail me? firehead@rogers.com
Posted on Jun 11, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 497 Answers
SOURCE: durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Posted on Aug 12, 2009
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    My karcher pressure washer 520 M is leaking water from the hand gun
    You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
    May 22, 2012 | Karcher K2.26 Electric Power Washer
    Water gushing out of gun handle
    Looks like the frost has damaged your gun. A new gun is required.
    try this link for spare.
    http://www.sparesgiant.com/c-19-pressure-washer.aspx
    Mar 28, 2011 | Karcher Garden
    I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
    Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
    Feb 28, 2011 | Garden
    Water leaking from spray gun
    It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
    If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
    Jan 02, 2011 | Karcher Garden
    Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
    You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
    Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
    Faulty
    water is pouring out of my 5 year old karcher from the trigger handle WHY???
    May 22, 2010 | Karcher PSI Electric Pressure Washer
    Leaking water
    The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
    Jun 18, 2009 | Karcher K2.26 Electric Power Washer
    High pressure hose. How do you get if off the karcher k 3.99
    there is a small clip on the triger where the hose attaches to is, pull clip out pull hose off
    Jun 16, 2009 | Karcher K 5.85 M Electric Pressure Washer
    Garden Logo
    525 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
