Question about Samsung SCX-5115 Fax Machines
Screen shows "open heat error" - Samsung SCX-5115 Fax Machines
    President:
  • 3,085 Answers
Replace the FUSER
Posted on Jul 03, 2010
Washing Machine Aquarious Ultima the screen shows F 05 ? it does not finish washing and the door can not be opened
Hello there:
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Dec 26, 2010 | Washing Machines
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
Dell 1815dn error code "open heat error?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 29, 2009 | Dell 1815dn All-In-One Laser Printer
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
We have a xerox c20 copy machine. Yesterday it stopped working and an error message showed up on the screen as follows "Open Heat Error" The copy machine will come on but after the warm up...
You need a fuser.
What has happened is there is a heating mesh in the heat roller that has gone bad.
It is a very easy repair.
Here is the best place you can order it from. Ask for Britt ok?The part is in the $200 range. You open the right hand door like you would to remove a jam. There are 4 silver phillips screws, and one plug you disconnect. Takes maybe 5 minutes to replace.
I know of no one who spares just that particular roller since it has a very unique heating element.
NO it is not me, just a very reliable parts source I have dealt with.
https://www.partsdrop.com/store/
Apr 19, 2008 | Office Equipment & Supplies
Open heat error
when i on my scx-4216 samsung laser printer it show on screen open heat error on display screen
tell me the solution
Apr 17, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-5115 Fax Machines Logo
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
