Question about Whirlpool Refrigerators
I have a whirlpool refrigerator #2ED2CHQXT05. Ice
I have a whirlpool refrigerator #2ED2CHQXT05. Ice maker stopped working last week, It is also making a loud noise on left side of unit(the freezer side). I have turned off the water supply, thinking it had to do with that but it hasn't stopped. I removed the ice basket & cleaned the complete area. I also tired putting water in the ice maker. It froze but did not drop into bucket while in the ''ON'' position. Any thoughts?
  • kmayer926 Jul 03, 2010
    I think we already checked the compressor belt- any other possibilities?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • 503 Answers
it may have been ice. I doubt it as ice tends to not form that close to a fan so that it makes enough noise that you can hear it. If it does encroach it doesnt last for long unless the defrost system has failed all together.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
  • Monika Arora
    Monika Arora Jul 04, 2010
    You can try the below mentioned steps........
  • Step 1
    Check the position of the lever that is just above the bucket into which ice cubes fall. When there is a lot of ice in the bucket, this lever gets pushed up. When it is in the "up" position, it essentially turns off the ice maker. Even after you have taken ice from the ice maker, the lever can sometimes get stuck. Simply push the lever down, and there is a good chance the freezer will begin making ice again soon.
  • Step 2
    Check the connection hose in the back of the fridge. Behind the freezer, there is a small hose that connects from the wall to the freezer. It almost looks like a cable. If this plug is pinched or not hooked up completely, the water is unable to flow into the refrigerator, thus the ice maker cannot make ice. Scoot the refrigerator from the wall, and check the connection to make sure it is tight and not blocked.
  • Step 3
    Feel the filling hose inside of the freezer. This hose is located just above the ice maker. Ideally, the water flows from this hose into the ice maker and then ice is made. However, one of the problems that sometimes occurs is that the water can get stuck inside this hose and freeze. If this occurs, the ice in the hose blocks any water from coming out.
    When feeling the hose, bend it to see if it is flexible. If it is not, use a hot washcloth and wrap it around the hose. This will help melt the ice inside and allow the water to flow freely.
  • Step 4
    Check the freezer temperature dial. Although the temperature for water to freeze is 32 degrees F, an ice maker needs to have a colder temperature than that to quickly and efficiently make ice. The Kitchenaid ice maker should be set to somewhere around 10 degrees F. Change the temperature setting, and check back on the ice maker in a couple of hours to see if more ice has been made.
  • Step 5
    Remove all of the ice from the ice bucket to see what the inside of the bucket looks like if the ice tastes funny. After some time, the coating inside of the bucket can erode. When this occurs, it gets mixed in with the ice and makes the ice taste strange. This can be fixed by getting a new ice bucket for the freezer.
  • 532 Answers
Hello, First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Thanks for contacting Fixya.
    Genius:
  • 1,354 Answers
Hi
chack your comprsher belt may it not working properly
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool stopped making ice, water side is fine.
Hi!
Please check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 27, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Apr 07, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
