Question about Vizio L37 Television
How do I change from 720 dpi to 1080 dpi on my Vizo 37" tv
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Buzzing sound
Hello, This is a problem with the switching transformer or the ballast used to fire the backlight. You will have to replace the ballast and or the switching transformer soon. In order to replace these items, I would suggest taking it to a qualified TV technician for servicing. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
SOURCE: I have a Polaroid 37 inch Tv model FLM-3732.
It turned out great!!!! replaced the capacators within 30 min and $3.50 in parts!!!!!!!!!
  • 1779 Answers
SOURCE: how do I get 1080 on TV
You only get it if they send it. Only Blue Ray DVD's are in 1080p and games I suppose, as of this time. everything else is 480i or 720p. As your manual says "TV CAN GET"--- not produce what isn't there. I hope this helps.
Posted on Jun 24, 2009
  • 102 Answers
SOURCE: DVD hockup to 37"VIZIO TV
There is no reason that any video player with RCA video/connections cannot be used with your new TV. However, you will not experience any increase in definition, even if your TV is High Definition.
If you used a Component connection from your DVD player (three cables for Video), all that is required is that your TV have Component cable inputs.
Posted on Oct 10, 2009
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Bravia 32in. why 720 not 1080
You need to contact sony on this one. I am pretty sure that is a 720 model. 1-800-222-7669
Apr 09, 2014 | Sony BRAVIA 32IN LCD TV 720 MOTIONFLOW...
Invalid format when connectin Hp to a 50 inch Zenth
The obvious, make sure TV is set to correct input. VGA, DVI, or HDMI are common connections. Test PC resolution at 720 dpi or 1080 dpi.
Oct 10, 2012 | HP Computers & Internet
Cant get the tv to go from 720 to 1080
Changing the resolution of 720 to 1080 is dependent of the input television. Make sure the HDMI cable connection or a PC cable connected properly.
If you uses a PC input, you should set the resolution with 720 to 1024 first. then set to higher resolution. If there is a problem when doing settings dark picture or not support, it means that the TV does not support the resolution.
Perform way above the HDMI connection too.
Hope this helped solve your problem.
Mar 12, 2011 | Samsung Televison & Video
Is it 720 or 1080?
The screen resolution for this TV model is 720.
Sep 09, 2009 | LG RZ-37LZ30 37 in. LCD Television
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
Buzzing sound
Jun 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
How to change picture quality from 480 to 1080?
needs to be hooked to the tv with either an hdmi cable or componet(blue/green/red.yellow/white/) also check the game on the back of the box. some games are only made for 480 and 720
Jan 02, 2009 | Olevia LT37HV 37 in. HD-Ready LCD...
Changing from 720 to 1080 dpi
The tv should select the resolution automatically depending on the input - if you have an input from a pc and you wish to change the resolution then page 58 of the manual (link below) tells you how to change this on a common pc. all other inputs are usually set - although some newer devices may have their own menu that allows you to also adjust their resolution. http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf page 67 describes how to switch items in the device menu if the appropriate actions are not working then i suggest you get the remote serviced or replaced - ask again if you need help sourcing a new one. Hope this helps :)
Dec 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Vizio L37 Television Logo
415 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
