Question about Nintendo Game Boy Advance Console
Red ring flashing - Nintendo Game Boy Advance Console
  • 81 Answers
If you bought your Xbox 360 within the last three years it is still under warranty for the flashing red ring error.
Go here https://service.xbox.com/
Register your Xbox and request repair service, you will not have to pay for anything and get a new 360.
Posted on Apr 18, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
I HAVE THE MERLIN PHONE SYSTEM 820D2 I WOULD LIKE TO SILENCE CERTAIN NUMBERS FROM RINGING. HOW DO I DO THAT?
Now that's an oldie :-) I have the instructions squirreled away right here
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 freezing and red ring flashing
Im sorry bout the xbox, trust me i know how it feels for a system to mess up and ive read the Xbox 360 flashing red, is indicating some major trouble is about to go down.
sorry for the bad news.
i hope i have helped!!!!
Jan 05, 2010 | Microsoft Xbox 360 Console
Red ring flashing
Red lights is normally the red light of doom, you will need to send it in to get it fixed or you can fix it yourself using a good guide to fix it and stop the heat build up.
Dec 26, 2009 | Microsoft Xbox 360 Console
Three flashing red lights
If you have the 3 red lights this is because the GPU and the CPU have heat up you need to stop the heat, you can send it in to do this or you can fix it with a good repair guide
Dec 24, 2009 | Microsoft Xbox 360 Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox red green flashing lights
r they all red or only certain ones the most common thing to check first are the av cables/hdmi cable from the xbox to the tv.. if they are loose on the xbox it will show the red ring in a sequence make sure their tight...if this does not fix it YOU HAVE THE RED RING OF DEATH its either overheated or you have a bad disk drive or something internal....you will need to call microsoft
Feb 23, 2009 | Video Game Consoles & Games
Nintendo Game Boy Advance Console Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
