Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Problems in foxconn matherboard short long beep give me solutions
  • 76 Answers
The short long beep means no memory card detected, probably plug incorrectly, release them then plug smoothly and correctly
Posted on Jul 03, 2010
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
When I power my pc matherboard give lon sound and continue
Check the memory is pushed in fully and the fan is properly connected. If it proceeds normally after this it may be standard boot procedure - some old motherboards give a long beep during startup. (if none of the above works, you could try resetting the bios) Hope this helps! Max
Feb 10, 2011 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
How will you absorved no display
I have looked at a PDF of your manual, but it did not give the BIOS (Basic Input Output) type. I did see a screen shot referencing Phoenix-Award BIOS, so I will give you the video adaptor error for both BIOS manufactures.
Award - You will hear one long beep and two short beeps from the speaker, which is a video adaptor error.
Phoenix - You will hear three beeps pause, four beeps pause and one beep from the speaker, which is a video adaptor error.
If you hear no beeps at all or another sequence of beeps from your speaker it could be another problem.
You can install a PCI Express video card in your computers PCI Express slot to test your on-board video.
Jul 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Three beeps repeating at startup, Foxconn P43A
Foxconn uses the Award bios. 3 bios beeps / repeating means there's a memory issue.
http://www.computerhope.com/beep.htm
(Remove, clean & reseat).
Do not clean the DIMM's with an eraser. Use house hold alcohol.
Dripped onto a cotton swab & wipe the contacts off.
Clean the DIMM slot & reseat.
On the outside, if the 3 beeps repeat run a memory testing program. Click this link below, scroll down & under the three screen snapshots download you're flaviored software. One allows you to create a bootable floppy disk & one allows you ro create a bootable CD. Main site: http://www.memtest.org/
Download - Pre-Compiled package for Floppy (DOS - Win)
Download - Pre-Compiled Bootable ISO (.zip)
Main web site for Foxconn 755A01-6ELRS
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
Good luck Pbacatmac!
Mike
Aug 03, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
120 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
