Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
COMPATIBILITY WITH DDR2 RAM
CAN I CHANGE MY OLD RAM WITH WITH 2GB DDR2 RAM ON THIS MOTHERBOARD OF MY DESKTOP
  • 570 Answers
Yes you can do it.But you have to place first RAM in the first slot and other in the other slot,this makes it easy
But surely you can do it.
Please rate me if this solution works for you
Thanks......Have a great time
Posted on Jul 03, 2010
  • ASUS Master
  • 11,800 Answers
No, on that motherboard you only have support for DDR266
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Can my mercury motherboard PI945GCM.V1.0 support 4(2+2) gb ddr2 ram
This motherboard will support only Maximum 2GB DDR2 RAMS.
Thanks for using FixYa.
Jun 06, 2011 | Mercury P4VM800M7 Motherboard
Motherboard acer A1100-B1300A.... ????
Knowing the model of the mobo will not do anything if you know it takes
DDR2 5300.
And you can find tons of 1GB,2GB,4GB sticks.
If you want to know what memory MFG are compatible with you system
go to the Acer website.
As you can see at the website I posted below there are a lot of memory you can get.
Here are 12 different brands of 5300 2GB sticks of memory.
If your sure the motherboard takes 5300.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170147%201052408745%201052307859&name=2GB
Feb 08, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Does intel desktop board d945gccr support DDR2 Ram 667 or 800 MHz
intel d945gccr supports ddr2 400 mhz & 533 mhz it maximum support ram is 2gb
Nov 22, 2009 | Intel D945GCCR Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Supporting the DDR2 RAM
Asus site says the motherboard supports DDR or DDR2 RAM up to a max of 2GB.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=814&modelmenu=1
Oct 21, 2008 | ASUS P5VDC-MX Motherboard
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
