Question about Wacom Intuos2
Wacom babmboo pen does not work
Since I accidentally dropped it, tne pen of my wacom babmboo tablet MTE-450 does not work propperly. the tip does no do anything at all and when I use the other end it does not work in the usual "eraser" mode but in a very slow "normal" mode.
it is as if the functions of tip and tail have been partially inverted.
is there a way to fix that? if not, where can I order a replacement pen for the babmoo tablet?
...I tried to use other pens for other wacom tablets but they do not work.
  • 2 more comments
  • Sasunaru Dec 19, 2008
    Same here D: Do i have to replace the Tip?
  • Anonymous Jan 01, 2009
    Exactly the same, please, help!
  • Anonymous Feb 13, 2009
    my pen will only work in mouse mode.. for some reason it wont work in pen mode :(
  • Anonymous May 11, 2009
    mi electronic pen, does not work. just the erraser part can make a move on screen, ... does wacom sale replacements anf aditional pens?
    Problem Solver:
  • 6 Answers
If the eraser part of your pen works but the business-end doesn't, this fix may be for you. Since the only option is to replace the whole pen, it's worth the try. The interesting part: There is no "live" powered electronics in the pen (it is a simple L-C circuit for you tech-weenies out there) - truly the only way to make the pen not work is to drop it and knock it out of adjustment, use it as a crude paper punch, or get it soaked with some type of fluid such as coffee, beer or soda. The pen is an excellent design is designed to just eventually wear out. My pen is 10 years old and still looks new.
I needed a small jeweler's screwdriver for this fix (1 mm to 1.2 mm width). Carefully remove the rocker switch from the pen; it just pulls out. Don't lose it. See the image below: there is an itsy bitsy slotted screw-like device in the center (it's a tuning capacitor). For its location, follow the white arrow in the picture I've attached. Prior to turning, memorize where the slot-head points (there's a tiny triangle on it), and if possible, use a fine point sharpie to mark the screw before you adjust it. It is not a "screw" per se, but an adjustable capacitor and part of the tuned circuit.
The adjustment: Place the pen as normal on the tablet and "tweak" the capacitor by a small 1/16 or 1/8 turn in either direction until the pen reacts. If it has gotten out of "resonance" this tweak should kick it back in.
Posted on Feb 08, 2011
My Wacom pen doesn't work. The blue light on the tablet turns green when I touch the pen to it, but the cursor doesn't move on the screen. I thought that the tip needed to be replaced, but after changing...
Does the mouse work (on the tablet)? What happens when the side buttons are pressed do they work? Try un-installing the Wacom driver (Pen Tablet Utility) and Install the latest version from www.wacom.com and see if that helps.
Mar 05, 2011 | Wacom Intuos3 Graphic Tablet
I dropped my wacom tablet pen and now only the eraser is working!
...and it landed right on the tip, breaking the sensor, which could probably be tracked down and replaced.
... it landed on its side and has a mechanical malfunction which can be fixed by opening it and using careful observation and Yankee Engineering!
...or saving time, effort, and probably money, getting ahold of Wacom about a new one (BUT where's the FUN in THAT?)
GL!
Aug 24, 2009 | Wacom (EP130EPE) Digital Pen
My Wacom Bamboo Tablet Pen: only the pen was dropped. Now the eraser works but the pen tip does not. Neither do the buttons. The tablet itself does not pick up the pen tip's presence, but it works perfect...
Try replacing the pen nib. Take out the little nib with a tweezer or something along those lines and replace it with a new one. There should be a few of them when you bought the tablet. Also, try looking at the tablet properties.
Feb 02, 2009 | Toshiba Portege M200 Tablet PC
Wacom Bamboo Fun Pen isnt working correct
I think you dropped the pen on its tip and broke the little ferrite sensing core.  You can try to repair it by gluing the core back together - it worked for me.  For detailed instructions on how to do it, go here: http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html  or you can try to swap the core for the eraser and the tip (more involved - you would need to be very good with a soldering iron to attempt this).  Either way - it's unfortunate that the pen is so fragile and that the user manual doesn't really warn you of this.
Jan 17, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Pen Won't STOP Working
Well... I contacted Wacom support and the guy who write back recomended me to change the nib, to turn 3 times the eraser and to hit 4 times with the pen onto your palm hand...
Of course I didn´t do anything like that, I mean, what´s that??? An spell of some sort (or what)???
But what I did was the following (MAC-OS user):
-Enter to the pen tablet options on your preferences
-Switch the sensitiveness of the pen to the hardest
-Run an app that work´s best with your tablet and make some lines to check if at least in this mode the pen works
-Return to your tablet preferences and adjust at your best
I can´t explain why but my stylus is working fine again...
hope someone find this useful...
Oct 20, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Broken Wacom Bamboo Fun Pen
^ I believe this is exactly what you need to know. :3
Aug 25, 2008 | Wacom (EP130EPE) Digital Pen
Replacement Stylus for tablet?
i just happen to have come across this site while looking for another stylus as well, so i went back to my google search and found this :D
http://www.adorama.com/WABP.html?sid=1216684387994534
what a coincidence eh?
Jul 21, 2008 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Pen Tip Not Working
I had the same problem and called Wacom Customer Care at 360-896-9833... I was informed that the pen was defective/ broken and needs to be replaced. This can be caused by being dropped and such. I was told that i should keep the pen on the stand or a eyeglasses case when not in use.
If your tablet is under a year old, warranty will cover the cost of the pen with proof of purchase. Other than that, you will need to purchase a new pen (about $29.99 from Wacom & online).
Unfortunate, but great to know.
Jul 16, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom Intuos2 Logo
1,044 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
