Question about Cameras
What does iso mean on the setup on the camera and what do i have to do to get my flash work it isn't working ?
    Brigadier General:
  • 11,967 Answers
ISO refers to the sensitivity to light of the sensor. It's like film speed ratings on film cameras (ie. a 400 speed film is four times faster than a 100 speed film). There should be a button with a lightning bolt icon on the back of your camera. Press it and watch the screen for different options for flash. Stop when you get to the "A" or "Auto" plus the lightning bolt.
Posted on Jul 03, 2010
3 Suggested Answers
neta
  • 852 Answers
SOURCE: How does the ISO work on a Digital Camera
Basicly the charge in each pixel on the CCD chip is sent to another chip that converts it to a number. The charge can be amplified before conversion to get larger numbers. The more the charge is amplified the higher the ISO rating, the problem is that noise is also amplified. Just like if you turn up the volume on a weak AM radio station the static is also louder. I'm not sure how the cameras decide on what ISO to use in auto mode, each one is probably programed a little different.
Posted on Sep 11, 2005
  • 919 Answers
SOURCE: Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Posted on Feb 11, 2009
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
This should resolve the issue.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
FUJIFILM FinePix S2500HD bought two months ago. Flash is now refusing to work. Please help!
Same problem with mine - bought in February, (now May!) flash doesn't fire. Indicator light flashes orange which the manual says means "flash charging" but still no response despite waiting for that to complete.
Hope this isn't a bug in this model... Fujifilm, where are you?
Nov 07, 2010 | FUJIFILM FinePix S2500HD / S2600HD Digital...
My Canon 550d is new and right out of the box on full auto indoor pics are dark. If I go to no flash mode they are much brighter. It's like the flash is out of sync. Is it the camera or me?
the flash only covers a certain range and the built in flash has quite a small range. so lets say its dark in the room and you take a shot of a person they probably look really bright but the background is pretty dark, thats pretty normal and its better not to use flash, now in the auto mode without flash it will be using a higher "ISO" number to get you brighter shots indoors. shots may look slightly grainer but it means its brighter and the 550d handles low light pretty well.
in auto mode you have no control over the ISO but put the camera into P mode which is basically auto but with access to more controls which you can override. now next to the shutter button there is an "ISO"button. experiment with the different numbered setting (100 being low 3200 being high) and you will see what I mean
Oct 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Flash does not work
Please note that:
1. You can not use the Flash when the Camera is set to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection.
3. You can not use the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is fully charged and the flash is turned ON.
Please set the Landscape mode or Snow mode or Beach mode in the Scene Selection and check if the flash is working.
5. Try initializing the Camera and check if it works normally.
NOTE: Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
6. Please press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
7. Try to power reset the Camera and check if it helps to resolve the issue. I suggest that you reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
8. If the issue still persists then the Camera requires service.
Good Luck!!!!!!!
Oct 26, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Flash wont work, settings are on for flash, and the multiburst is switched off.
Please note that:
Good Luck!!!!!!!
Oct 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Cannot take indoor photos without flash
Just as "Wrestling" explained, your camera is operating properly. There simply isn't enough light in the scene that you are trying to photograph. If you're new to photography, it's sometimes hard to remember that the human brain/eye combination is an incredible thing, and no camera can compete with a human being.
What I mean is, there is enough light in your room for your eyes to see detail, but not enough for your camera to 'see' the detail without additional light from your flash. However, there are a couple things you can try.
1. Raise the ISO setting on your camera (check your manual, it's easy). Turn the camera on, press and hold the ISO button (left top of camera) and rotate the main command dial (back of camera, upper left corner). Rotate left or right to lover or raise the ISO number. Watch in the top information panel as the ISO numbers change. Higher ISO numbers mean the camera is more sensative to light; you can take pictures when there is less light available. HOWEVER, there is a trade-off. The higher your ISO number, the more noise/grain your image will have. I think the ISO of the D200 is acceptable for enlargements (8x10's) up to about ISO 640 or 800. I'm very picky, you might find higher ISO settings work fine for your needs, especially if you are not making larger prints. Experiment! remember to change your ISO back to a lower setting when you're done with your low light pictures.
2. Take your camera off the fully automatic "P" mode (where the camera makes all the decisions), and change your shutter speed to a slower speed. The slower shutter speed lets more light into the camera, because the 'eye' (the shutter) is open longer. (Use the "S" mode where you set the shutter speed and the camera selects an appropriate aperature). HOWEVER, there is a trade-off again. The slower your shutter speed the more likely you are to have blurred pictures; your subject will move or your camera will shake. If you're taking pictures of a stationary object or an adult, you can tell the person to sit very still and experiment! As for reducing camera shake, first and foremost, learn to hold the camera properly. I can't stress this enough...it's the biggest reason for blurred photos that I see. learn/practice squeezing the shutter realease, not stabbing it. Then, invest in a lens with the Vibration Reduction feature.
3. Take your camera off of the fully automatic "P" mode and change your aperature. (If you like, you can use the "A" mode where you set the aperature and the camera selects the shutter speed for you). The aperature is how wide open the shutter "eye" opens with each picture. Think of your own eye. In bright sunlight, your pupils close down to small openings, as there is a lot of light available. If you are in a dark room, your pupils open as wide as possible to let as much light into your eye as possible. That's the same way a camera works. So, if you are in a darker room, you need to let more light into the camera...that means a larger aperature. The tricky part to remember is that the LARGEST aperature has the smallest number. That means a 3.5 aperature is a larger opening than an aperature of 16. HOWEVER, once again there is a trade-off, as a larger aperature means you have a smaller depth-of-field; depth of field means the area of your picture that is in focus. I'm sure you've seen landscape photos, where every detail is in sharp focus, the far away mountains and clouds, as well as small rocks and grass or a steam in the forground. That is created by a small aperature with a wide/deep depth of field. Then think of a portrait in a magazine or taken by a studio, where the person is in focus, but the background fades off into a pleasing blur. That's done with a large aperature and a narrow/shallow depth of field.
NOTE: The widest aperature available is determined by your lens, so you can't use all the aperature settings with every lens. Your camera knows this and will only adjust to whatever your lens has available. That's why you might have different settings available with different lenses. Experiment!!
OK, sorry if that was long-winded, but the D-200 is a great camera, yours is operating properly, and I want you to enjoy using it!
Jan 01, 2009 | Nikon D200 Body Only Digital Camera
Flash not working
this could be a number of problems first soloution gently hit the side of the camera where the battery is stored
if the dosent work try to pull and twist the lense gently
has the camera started to vibrate yet? and my other soloution would be
  1. ress Menu button
  2. togle across from REC Mode to setup
  3. togle down thrice from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
  14. If it is working then don't forget to set your Clock.
Sep 08, 2008 | Cameras
Flash doesnt turn on
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
Jan 24, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Flash doesn't work right
first step would be to reset the camera in the setup menu - reset settings and setup parameters - turn camera off for about 15 seconds then back on and take a snapshot in simple mode (heart icon) on the mode dial. If the picture turns out problematic it could be a flash or image sensor issue - if it comes out fine then it was an issue before with the settings - possibly the ISO sensitivity.
Mar 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
