Tip & How-To about Car Audio & Video
Rules of thumb:
1) Do not cut
steel frame more than 20% larger than nearest hole (Don't be a smart *** and join the dots of factory holes to make a bigger hole either!)
2) Use
pods/spacers to mount you speakers into this way you can put in larger,
different shaped, custom designed enclosures, etc that do little damage
to original trim and can be removed later if you so chose.
Assuming
that you are putting speakers in to front door panels:
Remove
door trimming and take note of removed components (Take pic's as you go
it's easier)
Compare original speaker to new ones (in particular
the depth of the cone) Factory tend to be shallow while after market
ones deeper for better sound. Note depth difference.
Try your new
speaker in the rough location you want it and wind down your window all
the way and see if it will interfear with the mechanisms of the door.
If it clears everything your laughing and just have to unscrew the old
and replace with the new or...
Now the fun bit do the math on how
much the difference is and how much you will have to space it out for
it to fit into the door with out interfering with it's components,
decide if you can deal with the speaker sticking out as far as it has to
to fit, or can it be put in a different location. (Have a friend or
family member help you with this so your hands are free to sit in your
seat and feel it out, no point in putting it in if your not going to be
happy with the end result)
Once your happy with your positioning
make a blank up of a pod out of MDF (NOTE: MDF when cut/sanded creates
toxic dust use appropriate Respiratory Protective Equipment (R.P.E.)
such as a P2 paper mask as well as Personal Protective Equipment
(P.P.E.) e.g. safety glasses, hearing protection and gloves) to make a
shape that blends in with your doors contours and has a hole big enough
for your new speaker to fit into. Dose not have to be perfect just yet
as you shall have to mold it to suit what you want it to look like. Take
your time and sit it in place till you are happy with the shape and
placement. Make sure door closes and opens with pod.
Use this
Blank to cut out a second pod just like this one (for the other door)
Shave
off sharp corners
Match fabric to door trim (or go all out and
highlight it in a contrasting cloure/pattern/texture)
If fabric
stretch it over pod and staple into place (better yet glue some thin
foam to pod first then use some spray addehisive to attach fabric to
foam then stapel behind the pod to hold securely)
Vinal is a
different story and requires spray adhesive heat and working it into
position then stapling.
Good Idea to place speaker cage into place
and secure to hold fabric around it. (Cut away excess in both cased
inside cage and behind pod for a flat joining)
Mount speaker to
pod and lay pod on a table placing door trim over it. Maneuver to
correct position and use correct sized screws to join them together.
Connect
wires
Test speaker
Replace modified door trim on to door
Repeat on opposite door
Fin.
