Question about Toshiba Satellite Pro L300 Notebook
Toshiba L300 Case Repair !
Basically
Where the charger fits into the case to charge the laptop
the plastic cover has broken and it taken a well balanced lead to charge my laptop.
Its rather stressing.
Any repair guides for fixing this problem.
  • Toshiba Master
  • 32,281 Answers
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Posted on Jul 03, 2010
Charger not staying put
Sounds like the socket is faulty, probably broken the supports inside the case. Only way to fix it is to take it apart and either repair the socket or fit a new one. It could be quite expensive depending on how much of the laptop needs taking apart. I repair them quite often but am in the UK people pay anything from 60 dollars to 150
Feb 04, 2012 | Compaq Presario CQ60-220US PC Laptop
Tip
Repair a Broken Plastic Tab / Latch on a Carrying Case
Has the plastic latch on your toolbox or carrying case weakened or completely broken off?
Use a bicycle tube repair patch to re-attach a broken plastic tab or reinforce a weak latch on your tool carrying cases. The rubber patch is designed to vulcanize (basically stiffen) after application and the adherence is great. I layer two on each latch in opposite directions to improve strength and cover a larger area.
Be sure to thoroughly roughen the plastic and remove all "shiny" surfaces on the plastic with sandpaper for best adherence. Most bicycle patch kits include the patches, a metal tool to roughen the plastic, and the solvent necessary to react with the soft red rubber on the patch....and they are cheap - less than $2.
on Mar 06, 2015 | Hardware & Accessories
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba laptob Model # A205 S4577 freezee in between 20minutes i have shown to my friend he said the has to be replaced and even some part is burning at a point where you place your charger in your...
That part costs just $5. The labor to install it will cost about $200. But if the plastic of the board on which the charger port is fitted has been damaged by the burning circuit then it can't be replaced or repaired - the laptop is indeed dead. The laptop will have to be opened to see if that is the case - that will cost you $50 at a pc repair shop.
Aug 05, 2011 | Toshiba A205-S4577 Notebook
No power to L300 no leds on i have tried adapter and renewed socket and lead but still nothing
either the adapters are bad or the computer's power port is broken... orrr worst case the computer is damaged internally.
May 25, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite l300 not charging, doesnt work on the power supply
Try removing the battery completely and running it with the power supply connected. If that doesn't work, try borrowing a compatible power supply, or buy a universal one, and try with and without the battery connected.
The problem may be the power supply, in which case the battery won't charge and the laptop won't get any power.
Apr 06, 2011 | Toshiba Satellite Pro L300 Notebook
I bought a Toshiba notebook NB305-106 , model-part no: PLL3AE-00F00EAR and needs to be repaired as the charger if plug for charging would shutdown the unit, where can i shift it to have it...
In that case, the most cost effective way, in my view, is to order the socket from ebay and get an electronics repairer to fit it.
Hope that helps
Jan 25, 2011 | Computers & Internet
I have a toshiba equium l300, with no power at all
open it you will find if what is the problem.....open the whole case if not charging check also the dc connector of, check also the charger.
Jun 27, 2010 | Toshiba Satellite Pro L300-EZ1004X...
My computer is plugged in but isn't charging. I've taken the battery out numerous times and have unplugged and replugged the charger but nothing is working, my computer still isn't registering that the...
This is a common problem, these adapter go faulty all the time, you need to test with a meter, or get a replacement Power Adapter... You need to take out battery and plug in adapter all laptops should work, with just the Power Adapter connected, if it doesn't then it is faulty.. well that OR laptop.. When you get a new charger you will need to leave charging at least overnight to recharge the battery.
Mar 01, 2010 | Toshiba Satellite A135-S4527 Notebook
The Top Two Corners of my laptop
Hello.
In less than a year, your laptop should not have broken pieces, no matter what protective case you use. Unless you have mishandled, which you have not, the corners should be intact. The fact that you use a case and the pieces have broken, is even more significant to me. You should be able to take the laptop out of the case daily or many times daily without problems. The laptop is faulty.
Since your laptop is still under warranty, contact Toshiba repair. They should at least replace the chassis, where it is broken (if I am understanding you correctly).
Hope this helps.
Nov 26, 2009 | Toshiba Satellite P305D-S8900 Notebook
Toshiba Satellite Pro L300 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
