Question about SanDisk 4GB microSD High Capacity Memory Card
I have a panasonic lumix tz7, my 16gb memory card all of a sudden came up with memory card error! is there any way at all i can retrieve photos?
    Brigadier General:
  • 7,191 Answers
If the memory card is not corrupted or permanently damaged, the images can be retrieved by copying the images from the memory card to a computer using a memory card reader.
Use your computer's built-in memory card reader, if it has one, or you can purchase an external memory card reader/writer. (See attached image)
To do this, kindly remove the memory card from the camera and insert it into the memory card reader. Now, the memory card will be shown as a Removable disk in "My Computer". You can browse the images and copy the images to your computer.
Hope this solves your problem. Thanks for using FixYa.
Posted on Jul 03, 2010
  • jenniferirel Jul 03, 2010
    i have tried that but nothing seems to be coming up. does that mean pics are lost? Is there any other way I can get pics downloaded or does it sound like card is damaged?
  • AliTech110
    AliTech110 Jul 03, 2010
    Many thanks for the feedback.
    If your computer is able to access the contents of the memory card, i.e; the memory card is listed under "MY COMPUTER", you can try to retrieve the images using a file recovery software. You can download and install Recuva, a free file recovery software from: http://www.piriform.com/recuva/download
    After installing the software, kindly scan the memory card using this software.
    Thanks again.
How to Retrieve pictures
Insert the camera's memory card to your computer and run a photo recovery tool. Give this one a try if you're on a Mac. Recover Digital Photo Music and Video on Mac OS
Feb 23, 2015 | Panasonic Lumix DMC-TZ15 Digital Camera
How do i retrieve photos from my internal memory on my camera
Two options: remove the memory card before connecting your camera to your computer, or use the "Copy" command to copy pictures from internal memory to a memory card and then download from the card.
Jan 12, 2013 | Panasonic Lumix DMC FZ47 also known as...
Hi I cannot retrieve the photos from the internal memory - the ones on the sd card come onto mac straight away but not the ones on internal memory. Please help
Disconnect the camera, turn it off, remove the memory card, and then reconnect. Having the memory card inserted "hides" the internal memory.
Jul 22, 2011 | Panasonic Lumix® DMC-FS3 Digital Camera
My memory card was not in my Panasonic Lumix digital camera when I shot some photos. It said that it is stored in the buit -in memory . a- how do I retrieve the photos to store on my computer? b-how...
In the menu there is an entry for "copy" which gives you the option to copy the internal memory to a memory card for easy downloading. Then, when the pics are safely on the card, take it out of the camera and go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
Nov 04, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I need to recover deleted pics
I have had success with this... Download Asoftech Photo Recovery program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Apr 08, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Apr 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 10, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lost all the pictures on my camera Panasonic Lumix DMC-FZ7
A lot of Photo Rescue programs are available to recover your media card.
Mar 05, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
SanDisk 4GB microSD High Capacity Memory Card Logo
81 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
