Question about Toyota STF39 Mechanical Sewing Machine
Toyota 9600 sewing machine - upper thread snags on bobbin case
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
The bobbin won't spin and I can't thread from the needle
1. Check the tension of the bobbin and adjust. Remove the bobbin case and clean the race (little ditch the case rides on). A qtip works good for cleaning the race. Place one drop of oil on race and replace the bobbin case.
2. Replace the needle and make sure the needle is all the way up in the needle arm. When threading the top, do it with the pressure foot up. As you are threading give little tugs to check for snags. Any snags must be fixed.
3. With hand rotate the hand wheel towards yourself while holding the upper thread to the back of the machine.
IT SHOULD RISE FROM THE BOBBIN NOW. IF NOT IT WILL PROBABLY NEED TIMED.
Nov 23, 2015 | Sewing Machines
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
Would like to get a owners manual for my husqvarna 190 selectronic sewing machine. I am having trouble with upper tension and need to make sure I am threading it properly, any suggestions
Here's an ebay that has one for $ 15.00. There are others.
http://www.ebay.com/itm/Vintage-Viking-Husqvarna-Sewing-Machine-Operation-Manual-Optima-190-180-150-/191517822256?pt=LH_DefaultDomain_0&hash=item2c975a0d30
Generic threading:
START TO THREAD WITH PRESSURE FOOT UP. AS YOU THREAD GIVE LITTLE PULLS TO INSURE THERE ARE NO SNAGS.
1. Go from right to left.
2. As you feed you will come to the tension. Make sure it is fed through the tension disc or it won't work.
3. Feed through the take up lever.
4. Feed through the final holes to the needle. Final little pull to check for snags.
5. Put pressure foot down and give little tug. It should have some resistance, but not excessive. Usually four on the tension control is a good starting point.
6. Check your bobbin for pressure. Pull out the bobbin case and let it hang from your finger with the bobbin inserted. While you bob it back and forth it should extend one inch. Adjust the tension as you need to. Put one drop on the little ring under the case. (It looks like a race track).
7. As you use the machine you may have to adjust the upper tension as you need.
Feb 28, 2015 | Husqvarna Sewing Machines
Model 9600..thread keeps knotting up on bottom
Check the upper tension discs for lint: Raise the presser foot to open up the discs and blow or 'floss' between them. Any lint or thread in there will prevent them from giving the proper tension.
If that does not work then you may have a damaged hook and/or bobbin case that is snagging the thread. There are a few other reasons also, but you probably need to have it serviced to fix.
Feb 24, 2015 | Singer Sewing Machines
How do i fix the problem of my top thread tangling up and moving the bobbin case?
Remove your bobbin case and inspect it for any damage. Scratches, holes, snags. Sometimes you can Dremmel the snags.
Aug 10, 2014 | Singer Sewing Machines
Why does the top thread break on my sewing machine?
There are several reasons.
1. The thread spool slit that you put the thread through to keep the spool from unwinding when it\'s not being used could be catching the thread as it unwinds. Check to be sure that the thread can be pulled from the spool without snagging.
2. One of the guides that the thread goes through may have a rough edge, or, more likely, is covered in thread lint and gunk, causing the thread to be pulled. It doesn\'t take much to snag thread. Use a q-tip and alochol, clean all of the threading points on the machine.
3. The tensioner is another possible hang up. Make sure that the tension is not too tight for the type of thread or fabric that you are using.
4. The needle may have a burr or rough spot on it. Replace the needle to see if the problem continues.
5. The bobbin case is the last place of concern. there may be a lot of thread lint, or the bobbin case is not seated properly. Sometimes, the thread hood under the bobbin case needs cleaning. Following the cleaning instructions in your manual, remove the bobbin case and thoroughly clean in there.
6. Finally, check in your manual to see if anything need oiling.
Aug 01, 2014 | Sewing Machines
Kenmore sewing machine 16520
Bobbin case problems are common, and usually bobbin race parts are easy to find and not too expensive if you need to completely replace them. Otherwise I have successfully sanded down burrs on cases and races if that is what the thread is snagging on... ? Without having someone look at how it is snagging, it is hard to diagnose. Hope you figure it out!
May 01, 2014 | Sewing Machines
Question about a bobbin
First you have to determine if the thread under the plate is the bobbin's thread... or just great loops from the upper thread.
Bobbin snarls are caused by the bobbin unspooling in the wrong direction.
Burrs and snags on the carrier.
Upper thread snarls in the bobbin area are "operator error" Typically, upper thread not threaded correctly (foot UP, buttercup)... or neglecting to put the presserfoot down while sewing.
Good luck.
Nov 16, 2012 | Brother Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Thread on bobbin looping
Sounds like you need to adjust the bobbin casing tension (tighten the little screw on the bobbin case). I would also oil the face of the bobbin casing so that the thread wont snag or tug on it at all.
Jul 15, 2010 | Kenmore Sewing Machines
Toyota STF39 Mechanical Sewing Machine Logo
452 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
