I have a samsung AQV12 fan airconditioning unit. The problem is it will not work, the indoor unit has two green lights flashing and one red light flashing.
  • 1 more comment
  • deb_carringt Jul 03, 2010
    cheers i will try this
    ive tried your idea but no code comes up anythink else to try
  • Dave Martin
    Dave Martin Nov 08, 2011
    hi deb did you find how to resolve the problem as i have the same with 2 units in my house?
    President:
  • 4,070 Answers
Hi! Please try this. Remove the battery from the remote then insert it again. Press the up and down temp button at the same time and it will give you code. Please try to click on the link for it will guide you. Hope this helps and have a good one!
Posted on Jul 03, 2010
  • dj_relly999
    dj_relly999 Jul 03, 2010
    Alright, try this. Please unplugged the a/c from power source and let it sit for atleast 1hr. Plug the a/c again to power source after an hour and see how it goes.
Our church has 6 indoor units and 4 of the 6 the fan does not blow. The operation lights flash red and the timer light flashes green. Please help
Likely a setting issue on the tstats. Make sure they are setup for the right apllication, gas/electric
Nov 13, 2016 | Heating & Cooling
Initially fan in indoor unit was surging,cutting in and out,now has stopped completely and red/green flash twice followed by red flashing 4 times
The flashing indicates a fault code. Not knowing what make / model you have makes it impossible to determine the exact fault. If the indoor fan was running erratically, it may just be a fan capacitor on the indoor unit. Some units have a separate capacitor, some have the capacitor mounted on the main indoor control board. Check and see if the fan starts if you give it a flick to start it spinning when you turn the air con on. If it runs and the error flash does not appear, then you will know its a fan capacitor.
Apr 12, 2015 | Heating & Cooling
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
Fujitsu aotr34jct
Is the refrigerant at the correct pressure?
Dec 19, 2013 | Computers & Internet
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
When i start the a/c indoor unit working and after 1 minute of the indoor unit and blinking the green and red light.
Green blinks indicate communication to outdoor, but red light indicates communication problem. Check PCB.
Oct 16, 2011 | Samsung AS18A6RB Air Conditioner
The fan motor is on all the time with the controls shut off. I have to shut the unit off with the main breaker. The ac works but again the fan never shuts off. On the circuit board the LED flashes 8 times,...
The indoor fan or the outdoor fan? If it is the indoor fan the thermostat may be wired incorrectly or shorted. If the red wire and green wire in your thermostat maintain contact, the indoor fan will run all the time.
Aug 03, 2011 | Heating & Cooling
Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
May 31, 2009 | Heating & Cooling
Heating & Cooling Logo
215 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
