Question about Asko W6641 Front Load Washer
I cannot manage to remove the coin trap - it will un-do but I cannot pull it out. I have drained the trap via the black rubber ptpe. I can unloosen to trap [turn anti clockwise] but I cannot pull it out. It seems trapped or caught from behind
  • 351 Answers
SOURCE: not just your ordinary pintrap drain problem
check to see if there is a small coin in the grey drain hose that joins the pump also see if theres a coin stuck in the black sump hose to the pump.you will have to remove the front panel first.two screws underneath the front a one under the soap drawer.the paddles pull out put small screwdriver in the middle hole and pull hard toward you,they will come out also blow through drain hose to see if somthing stuck coins act like a valve and cause inttermittent draining problems,also check pump impeller isnt damaged it may look ok(white).hope this helps.
Posted on Mar 26, 2008
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
SOURCE: W620 Drain Hose Goes Where??
The little black hose in the pin trap compartment gets hooked onto the round pin on the door of the pin trap access, that little hose is a bypass hose from the pump inlet
hope this helped
Posted on Aug 02, 2008
SOURCE: water constantly in pin trap
I had this problem and found out there was something stuck in the drain hose.  It also made my clothes smell sour.  Unhook your drain hose stretch it out straight, run water through and maybe snake it if need be.
Posted on Aug 13, 2008
SOURCE: open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
Posted on Mar 10, 2009
HE-2 error what is it mean
Hi, on what I will assume is either a Kenmore or Maytag/Whirlpool washer, you have a drain fault,
To fix, you need to remove the lower panel on the front of the machine. Unplug the washer, pull away from the wall and tilt it backwards to the front of the washer is 4-5 inches up, and take out the 3 screws holding the panel on. Once removed you will see a drain pump. Get a bucket ready. On the side or front of the pump is a removable coin trap. Turn the trap handle counter clockwise to unlock and remove. Get your bucket under the opening as much water will come out. Check the coin trap for debris, coins, socks etc. If you find the trap is full of stuff, cleaning it out shoud solve the issue. IF is does not you may have a failed drain pump.
Jun 30, 2016 | Washing Machines
Error code 20
Is it an E20 error code? The E20 error code is usually something clogging the pump system follow these steps to check. From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yes, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside and remove any thing that does not belong, reassemble ant test.
Nov 25, 2013 | Frigidaire Washing Machines
The drain pipe fills so fast that the water over flows. My last washer never did this
The drain pipe may be partially clogged with lint. The old washer pump may have been a little weaker and didn't fill the pipe so fast.
Maybe someone can use an awger on the drain ptpe ...have to clean down to the J trap at the floor.
Hope this helps
Jun 27, 2011 | Frigidaire ATF6000ES Front Load Washer
IS NO SPINING AND I HAVE ERROR 20
The problem is a clogged coin trap. The coin trap is located below the front loading door near the right front side. To gain access is the problem. It is in a bad location and this will take a couple of hours to fix at a minimum. Tools needed, a phillips screwdriver, short handled perfered. A large set of channel locks. A set of flush cutters. Purchase a couple of hose clamps to replace the cheap factory ones. Unplug the machine. Disconnect the hot and cold water lines. Remove all water from inside the washer. Turn the washer on its side. Looking at the bottom you will see a black rubber device, with a grey hose (the drain)running into it, a white device hung onto it, and the top of the corrigated black rubber device is attached to the bottom of the drum. Disconnect all connections. This is not fun. Remove the black unit. Look down inside the unit and you will see a clear cylinder (usually filled with coins and lint) In short the clog which is not allowing the machine to pump out its water. Clean the unit and keep the coins for your trouble. Reinstall the black unit.(coin trap). Make sure the green clamps are properly seated or better yet replace them with the hose clamps. If you are unsure about the sizes take the coin trap to the local car parts store and purchase a couple. Make sure the rubber parts are replaced flushly or the repair will leak and you will get to fix it again, after swimming in a bit of soapy water when you sit the unit up again. Reconnect the hoses and power plug. Run a short cycle and check for leaks, by removing the back of the machine and checking for water leaks. Good luck!!!
Jan 18, 2010 | Frigidaire ATF6000ES Front Load Washer
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
Open coin trap
Mar 05, 2009 | Dyson Memory CRO1 Front Load Washer
Washer won't spin
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Oct 26, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Front load washer not draining
If the water is not draining the firt thing to check is the pump. take the 2 screws off the front bottom panel and remove it. get a bunch of towels or a wet dry vac ready. the pump should be on the right attatched to the drain hose and the coin/debris cather(a black rubber bladder. Remove the drain hose (use pliers on the clamp and pull the hose off. A lot of water will come out as well. Remove the rubber bladder(coin catcher) clamp with a philips head screw driver and pull it off the pump.Un plug the pump remove the monting screws. Check the pump and the bladder for debris. Look in the pump and make sure the impeller is not damaged. spin the impeller and make sure it moves. if the impeller is damaged then the pump need to be replaced. Assuming everything seems ok reassemble and run an empty load with the dial set just before final spin. If the pump is working you should hear it, and possible feel water moving through the discharge hose.
Mar 25, 2008 | Kenmore 44102 Front Load Washer
Asko W6641 Front Load Washer Logo
29 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
