Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Ge side by side model # GSS22JEMD BB
THE UNIT SEEMS TO RUN FINE BUT THE EVAPORATOR FAN ISN'T RUNNING. ANY WAY TO TEST IT COULD IT NOT WORK BECAUSE OF MOTHER BOARD. UNIT ISN'T IN DEFROST, COMPRESSOR WORKING,
CODENSER FAN WORKING THANKS FOR ANY HELP
    Genius:
  • 1,073 Answers
YES see if you have 12 volts dc at the evaperator motor if you do then the motor is bad if you do not then the mother board is bad and ge recomends in this case to also change the fan motor at the same time
Posted on Apr 17, 2008
Evaporator fan not running
I USUALLY REPLACE MAIN BOARD WITH EVAPORATOR FAN MOTOR AT THE SAME TIME. CHECK HOW ITS DONE ON MY YOUTUBE CHANEL. HOPE THAT WILL HELP.
Apr 01, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working fine but refrigerator not staying cold. If I unplug the unit and completely defrost and plug back in it works fine for a couple of days then starts to get warmer in the refrigerator. ...
Hi.
The self defrost system is defective. The parts comprised in the defrost system are the defrost timer, defrost thermostat, fan and heater. If the evaporator has separate coils for fridge and freezer (double evaporator), then there is also a three way valve that must be tested. Most refrigerators, even door-to-door have a single evaporator.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar with your model.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
Nov 13, 2009 | GE Refrigerators
PSW26PSTASS GE S/S Food Side Warm
Take the fan out and test it sepratley,Just make sure about the volts of the fan at first, if it runs then,you got your answer...
Good luck.
Sep 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
308 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
