Question about Garden
I have a Flymo 2200 Garden vac which cannot switch off unless disconnect at mains. I have opened up the machine, and cannot see any broken parts but the external switch does not appear to be connected to anything
  • 63 Answers
Theres your answer there should be 2 points in the switch houseing where it is conected
Posted on Jul 25, 2010
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
May 17, 2014 | Garden
Flymo trimmer 700 wont switch on
if you can disconnect the switch wires and it starts you will have to choke to stop machine . but you will know if switch is faulty , sometimes it just dust in the switch itself , try blowing switch with compressed air first .
Mar 11, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
Need hi-off-lo switch for Remington BV12200A leaf blower/vac. My son and I both have one with a broken switch.
may try ebay, or some sort of site like that.. maybe a garden swap meet. but otherwise, they went out of business and no longer make any parts.
Jan 14, 2011 | Garden
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Nov 17, 2010 | Toshiba E-Studio167 Copier
I have an L118...won't start unless I jump start it. On closer inspection, I found a disconnected wire...it's red in color and "hot". Have no idea what it goes to...could this be my problem as to why it...
Ok so where is it disconnected from? near battery, near ignition switch, near starter solonoid? How is it disconnected? unplugged? broken terminal? broken wire?
Jul 26, 2010 | John Deere Garden
Broken hinge on reservoir cover
The hinge itself and the lid are not orderable parts, unless you grabbed one off of a broken unit of the same model. The product does, however, have a 3-year warranty.
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart DCC-2200 14-Cup Coffee Maker
Central vac
It is possible that the low voltage wiring that controls your central vacuum has been damaged during the cable work. You can check to see if the low voltage relay is working by shorting the two terminals together at the unit. Just disconnect the two small (18-22 gauge) wires from the unit and short across the terminals where the wires connect. If the unit comes on, the vacuum is fine, and it is most likely the low voltage control wires that have been damaged. It should be a pretty easy fix, if you can get to where the wires are located. They are probably just pulled apart at a joint. Good Luck!!
Jul 10, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
