Question about Barbeques Galore Cook-On Complete Kitchen 4-Burner 167896 (LP) Grill
My bricque holder made of cast iron have broken was told no replacements are available what can I do
    President:
  • 3,085 Answers
What Kind of Steel Shot Is Used In Shot Blasting Machine?
Steel Shot Blasting
Usually, the hardness of steel shot can be improved to HRC40 ~ 62. It can be used in processing hard metal. It is more widely applied in shot blasting machine because of its excellent toughness and long service life.
Cast Iron Shot Blasting
The hardness of cast iron shot is HRC58-70. Cast iron shot is too brittle to be broken easily, so the service life is short. It is mainly applied in those processing of high shot peening strength requirements.
Glass Bead Peening
The hardness of glass bead is less than the previous two steel shot, which is mainly used in processing stainless steel, titanium, aluminum, magnesium, and other situation excluding iron pollution. Also, glass bead can be used in secondary surface treatment after steel shot blasting in the purpose of removing the iron pollution and reducing the roughness of workpiece surface. http://www.jxabrasives.com/
Jan 13, 2017 | Coffee Makers & Espresso Machines
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
Cast shell holder j20 ramset gun
You can try Eamset direct, but the tool is out of production for some time.
http://www.ramset.com/
Dec 15, 2012 | Tools & Hardware - Others
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
I have a cast iron wood stove that needs to have enamel repaired
They actually sell ceramic paint to repaint these. It should be available at your local hardware store. I repainted a claw foot bathtub with the ceramic paint kit and it looks like new again. If this helps please leave feedback...
Mar 12, 2010 | Heating & Cooling
I need to purchase a new oil boiler. which is better with hard water,, cast iron or steel. or is there no problem with either
i am told that with time the cast iron boiler will have problems due to the ph of the hard water, therefore the steel boiler is recommended.
Nov 18, 2009 | SySTOR Systems (400S52) Burner
Cutting cast iron soil pipe
Phil, I recommend a ratchet snap cutter as it will allow you to cut the pipe in a clean manner. These are available for rent at most major home improvement stores in the US. One can also rent one at a tool rental company. I rented mine for $35.00 the bulk of which was a deposit on the tool. Just a reminder when buying the coupling device ensure you ask for or get a 4 inch cast iron to 4 inch PVC coupling. A bit of vaseline will help you get the neoprene coupling to seat properly with the PVC if you encouter resistance. Good luck. If you need more assistance let me know.
Sep 25, 2008 | Plumbing
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Need cast iron bowl holder assembly for Hobart A-200
if your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
Dec 30, 2007 | Hobart A200 Stand Mixer
H Burner replacement
There are aftermarket cast iron burners available for approx $64.95. Otherwise, the OEM burner is a Dynachrome which is a chrome plated cast iron that is almost $300. I do not believe that the cast stainless is still available.
Jul 26, 2017 | Dynasty Grilling
Barbeques Galore Cook-On Complete Kitchen 4-Burner 167896 (LP) Grill Logo
89 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
