Question about HP LaserJet 2100 Printer
HP laserjet 2100
Text prints fine but photos, all of a sudden, are "washed out". I changed to a new cartridge but result is the same. Noticed lately that when I reinstall the print cartridge there is a loud "snap" just as the printer cycles (cycling is normal upon cartridge reinstall). Have you ever heard of this? is there someting I can do to fix it?
Bill Morse
wbmorse@wowway.com
    Scholar:
  • 87 Answers
You could do whats called a 1/2 test...put paper in the mp tray, do a print and when there is only about 2-3 inches of the paper sticking out the mp tray open the toner lid and lift out the toner cartridge..pull back the toner drum protector/flap and look at the image on the drum or the image that was about to go down on the paper...is it nice and dark on the drum..if so then you have a toner transfer issue...getting the toner from the cartridge to the paper. If this is the case then you may want to start with a new transfer roller. If the image is not dark on the toner drum then this an image formation problem. Some of the solutions here are bad toner cartridge (suggest using an OEM until problem isolated)....bad laser scanner or a dirty scanner....or a bad high voltage power supply ...
Inkworks
Posted on May 22, 2008
Printing laserjet fades from left to right on text only
Anthony try removing the cartridge and gently tilting backandforth a few times. Re-install for good news!
Mar 12, 2014 | HP LaserJet 4650 Color Printer
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
HP laserjet 2100 prints pages fine, but has "ghosting" and duplicating text and images several lines down from original text/image. Recently installed new HP toner cartridge and was working fine for about...
Sounds like a bad drum on the cartridge. Contact HP, and they will probably replace it free, or maybe help you to troubleshoot.
1-800 HP-INVENT
Hope this helps!!
Sep 05, 2009 | Sharp AL-1000 Copier
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
HP laserjet 2100 will not print PDF from Adobe Reader 9.0 correct
to print to pdf use software printers one can be found here
Dec 26, 2008 | HP LaserJet 2100 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
LaserJet 6L Prints Outlook content too light
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
HP LaserJet 2100 Printer Logo
88 people viewed this question
Ben Johnson
