Question about Toshiba Satellite A100-S8111TD Notebook
On my Satellite A80, I have to press F12 to start, cannot type letter e but e appears continuously on lots of places
  • 162 Answers
This is RAM issue. Please remove the RAM modules and reseat them securely. If the same issue persists, then the Service is required.
Posted on Jul 03, 2010
Types only one letter
Press margin release before you hit return then continue typing. You may have set the right margin.
Nov 18, 2013 | Royal Satellite 80 Typewriter
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Left side of keyboard 123456789 is not working
Do you mean the right side of the keyboard is typing numbers instead of letters?
If so, you have enabled the NumLk which turns the RHS of the keyboard into the number pad.
Press the NumLk key near F11, F12 function key and the NumLk LED will switch off and return your RH keys back to letters.
Jun 15, 2012 | Toshiba Satellite L500 Series Notebook
When i am typing @ cant instead @ the letter is " please help
The keyboard is set up wrongly or the laptop isn't one set up for your country.
If you get " when typing @ try typing SHIFT and 2 for the @ symbol.
You can change keyboard settings in Control Panel.
Feb 13, 2011 | Toshiba Satellite A60 Notebook
When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
Don
Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Acer aspire 3680
You need to boot with your windows vista cd and select repair install. This will reinstall the windows files, including the ntldr file, leaving your data intact. Make sure you only do the repair install, if you do the full install, it may wipe your data.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Acer Aspire 3680 Laptop
Trying to start from scratch
Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
  7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
    1. Type the following at the command prompt: X: (where X is the drive letter).
    2. At the prompt, type the following: ren boot.ini boot.in2
    3. Press Enter
    4. At the prompt, type the following: ren boot.bak boot.ini
    5. Press Enter
    6. At the prompt, type the following: exit
    7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
    If the above steps doesnt work then you will have to reinstall OS with the disks.
Feb 13, 2008 | Toshiba Satellite A105 Notebook
System not booting
take windows xp cd and repair from the cd
Sep 01, 2007 | Microsoft Windows XP Professional With...
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
