Question about Epson Stylus Photo R1800 InkJet Printer
I am hoping you can spare the time to help me with my problem? I have used a CIS with my Epsom R1800 for nearly 2 years with no problems. Then suddenly the ink light cam on constant. Opening the top I found 4 cartridges showing red lights (ink full) I used the SSC service utility and eventually got rid of 3 lights leaving Red on. I read somewhere on the Net that this meant that my red cartridge needed replacing. Living in Malta I had no idea where to obtain a new empty cartridge so I bought an completely new CIS which arrived today. I installed and now have 2 red lights Red and Blue showing and I cannot cure the problem SSC nothing. Do you have any ideas? Your help will be gratefully received.
  • stuartrose Jul 03, 2010
    I will try the methods you recommend and keep my fingers crosses many thanks to you
  • Epson Master
  • 11,800 Answers
The red light means that the IC chip located on the cartridge (on a CIS the part that slots in place of it) is faulty or it can't be recognized.
Since the problem has appeared simultaneously to all cartridges i think it's a printer problem, not a CIS one. Start by cleaning the connectors on the printing head then load some simple cartridges - new preferably -  to reset the sensors.
If the light is still there then the problem is inside the printer. in the head or the controller board. In both cases it will be necessary to get your printer to a dealer for a full diagnostic.
Posted on Jul 03, 2010
  • 1 more comment
    Thank you so much for your answer. I will do as you say, but sadly to get the machine serviced would mean sending to the UK and the expense of the postage it would not be worth it when added to a dealers charges. So if your suggestions do not work I will have to junk the printer - regretfully of course
    I removed the CIS and replaced with the only things I had at hand Epsom cartridges some may be empty!! No I have 3 red ink lights on. BUT the red is off???? The Magenta, Photo Black and Optimiser are on
  • Azrael SRL Jul 03, 2010
    Sorry to tell you but it appears that the contacts to the chip on the cartridges appear faulty. Use a q-tip with some printer solvent and clean them, next check that they move freely in their sockets and finally put the CIS set back in. If you still have problems try one more thing before junking the printer - buy a set of new cartridges (the cheapest you can find) and try again. If it fails even with that, sorry, it's time for a new printer
I have epson r230. In light magenta vertical lines appear, i run clean print head many times, but not resolved, in skintone green color appear. wht to do
In these situation you can try these procedure.
Take a empty cis . pour it with amonia solution ( water40% + amonia60%). set th CIS and run head clean. 2/3 times. put off Cis. set original cartrige/ CIS with ink. Run head clean.1/2 times. print a nozzle cheak. I Think you may relive from your problem.
Thank you.
Jun 28, 2011 | Epson Stylus Photo R220 InkJet Printer
I could not run canon MF 4150 as it shows E 225. What 2 do ?
Usually error regards to CIS. Do the following procedure. Press Menu,# Using key scroll to select Hardware test, press ok. Using key scroll to select CIS. Press 1 & check if CIS glows white Press 2 & check if CIS glows RED. Press 3& check if CIS glows GREEN. Press 4& check if CIS glows BLUE. Now press 5 and now CIS will be OFF If no problems found ,remove your platen glass reconnect the flat cable to CIS & apply Silicon oil to the bending parts of the flat cable which continuously touches the bottom plate. Now if still problem exists better to replace your CIS.
Mar 27, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Too expensive to run this printer
yes the inks are very expensive, but you can have a stratégie to reduce costs. make small tests before print an A4 or A3 picture. use a calibrating device to take off the color distorsion (if not, you will have alway the same cardridge empty first, usually red or blue). be carefull of the paper type, mat or glossy, they don't need the same ink quantity (specify it in the driver).
with a color calibration, you can also use generic inks, saving 50 to 70%.
However, the r1800 is a professionnal printer and the prints costs 2 to 5$...like professionnal prints!
Jan 20, 2009 | Epson Stylus Photo R1800 InkJet Printer
Te.co.ukFile opening error
Did you try uninstalling and re-installing the drivers. Uninstall everything including the canoscan tool bar, Arcsoft photo studio and Omnipage. And re-install.
Hope that helps,
Sai.
Jan 13, 2009 | Epson Perfection 1240U Flatbed Scanner
Epson R1800 with magenta blinking ,and wont recognize the said ink
Hi-
Try reseating all the ink cartridge, make sure you have the right cartridge for each slot and make sure all are genuine epson in. try another magenta ink as well if you have a spare. if all fails call epson at 5622761300.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Delete print queue in epsom stylus c46
Hi
Go to control panel, click on printers, look for stylus c46 icon, right click and cancel all documents. restart your computer afterwards.
Thanks for using fixya!
Oct 31, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper Selection on my Epsom R1800 & R800 using a MAC
Hmmm, I print from a Mac to an Epson Stylus Photo R1800 and a smaller HP inkjet one. What application are you trying to print from? And are we talking about the R1800?
Oct 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Magenta light blinking on epson r1800e....
Read the manual, says something about turning off for 30 seconds and bac k on again will reset
Jan 05, 2008 | Epson Stylus Photo R1800 InkJet Printer
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Epson Stylus Photo R1800 InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
