Question about Edirol FA-66 Sound Card
Dear Sir, My name is JOY and basically I am an arranger and programmer. At present , I am using EDIROL FA-66 soundcard for my programming. I think this sound card is superb and i have no problem with this. But one major problem is when i export the midi track to audio then the track is sounding so thin. The low frequency literally vanished. Only i can hear the mid and high frequency. So, please help me out this is the most and most major problem in my musical life. Why my sound is sounding thin from others? Whether i have to setup something?? please tell me the remedies. I will be waiting for your kind reply.
    Novelist:
  • 177 Answers
I need to know first of all what your setup is for output (you may not hear the low frequencies if you aren't running a sub, or if the sub woofer isn't configured correctly. Also check all of your output settings, including those settings for file conversions within each software used for these tracks. Another thing to keep in mind that you may also need to reinstall or update your soundcard drivers.
*Double check all your inputs/outputs to see that they are secure.
*Look in the control panel(s) and make sure that the equalizer settings are correct as well. It's common to experience settings to be muted in windows. You may have also blown your sub channel as well, depending on any amps/equipment you use (if you even do).
Posted on Jul 06, 2010
Hi, I can't install driver for FA-66, when it comes to the window PLEASE CONNECT THE FA-66 to your comp and turn the power on....I do that but than nothing is happening...any solutions??? thanks...
Check in "programs and features and make sure there is no software already installed for your unit. If there is unistall it and start over. I am guessing you are installing from a CD? You may have parts of previous installs that are conflicting with the completion. This Roland's site for downloads and they also have a support section.
http://www.rolandus.com/products/productdetails.php?ProductId=731&tab=downloads&skip=true
May 13, 2011 | Edirol FA-66 Sound Card
I'm using the FA-66 sound card with Ableton Live 8.1.1, and keep getting the message 'Failed to open te audio device' when I try to set my audio preferences. I know that everything works, because usually...
this error is usually shown when starting up an audio app while there's a different one already running... before starting up your AL8, check if no other audio programs are running (players such as WMP, Winamp, VLC, editors like Wavelab, ......)
Mar 09, 2010 | Edirol FA-66 Sound Card
Seem to have developed a problem with my audio recording and playback using Roland's FA-66 (Editrol). I use Cakewalk SONAR, Sony Sound Forge and Vegas Video softwares, and all of them show the same sound...
www.rolawww.scottyp-music.com/geardos/?p=21 nd.com/products/en/_support/dld.cfm?...FA-66
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
Nov 15, 2009 | Edirol FA-66 Sound Card
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
When I run my Akai MPC 1000 into my Edirol FA-66 get a loud hum through my monitors that does not pick up in the recording. I've tried switching around which power points that my MacBook, monitors and MPC...
its probably a ground loop (i think thats what it's called)
sometimes if a number of sound devices like monitors/computer/soundcard are connected
with the same ground, this problem occurs.
so maybe try use a ground-less electricity wire on the mpc, or the laptop. or both.
good luck.
lior
Mar 28, 2009 | Edirol FA-66 Sound Card
Edirol FA 66 firewire
Download/install the drivers from roland/edirol site for PC. For Mac, its plug and play. Just select the edirol in the audio options.
Oct 09, 2008 | Edirol FA-66 Sound Card
Problem with FA-66
Judging from the wiring diagram on the cover, the headphones are connected to the same output lines as 1 & 2. When you increase or lower the monitors. So do the headsets. The only way to get around it is to find a pair of headsets with at volume control into the wiring of the headsets or plug the monitors into outputs 3 & 4.
Here is the book I saw
Sep 14, 2008 | Edirol FA-66 (EDIFA66) Audio Input
Edirol Fa66 Problem
I bought the FA-66 because I use Cakewalk Sonar and they sell this interface on the Cakewalk site with thier name on it. I've had nothing but problems with this unit as described above. I've tried it on two different computer and it does not work on either. I also use an RME Fireface 800 on both these machines, same set up and it works flawlessly. Drop the Edirol/Roland FA-66 and try something else like an RME card or something. That would be my suggestion. It's a shame Cakewalk promots this piece of garbage. I've tried Edirol/Roland technical support and the guy just kept saying the sound card works fine, like it was just my problem.
Jan 06, 2008 | Edirol FA-66 (EDIFA66) Audio Input
Edirol FA-66 Sound Card Logo
93 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
