Question about Sony Ericsson K550i Cellular Phone
Why stwich off when working? - Sony Ericsson K550i Cellular Phone
    President:
  • 1,469 Answers
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
when a phone won't turn on and blinks red light, it 's either the battery cell
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Jul 03, 2010
2007 Nissan Xterra windows do not go up or down... Firstly. My drivers side window did not go up or down and no sound. All other 3 windows worked. I took the master stwich out and examined it and plunged...
See if all the wires have power. Sometimes you have a fusible link in the wires somewhere between the fuses and the switch. If no power could be a bad ground or the wires between the door and the body. Get a test light and good luck.
Jul 07, 2014 | Cars & Trucks
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
Steering column wiring diagram 1997F250 Floor shift
GET NEW STWICH AND ORDER A PIG TAIL HARNESS THAT THE HARNESS. DO 1 WIRE AT A TIME. DO A GOOD JOB SODER AND SHRINK TUBE ALL THE ENDS
Feb 14, 2013 | 1997 Ford F250 SuperCab
2006 monte carlo dome light staying on
ALL WAIST CHECK YOUR OVER RIDE STWICK THAT THE ONE YOU TURN OFF AND ON FROM THE INSIDE. . IF IT WILL NOT TURN OFF .YOU NEED TO REMOVE ALL THE DOOR STWICHES TO FIND THE GROUNDED CIRCUIT.
Jan 19, 2013 | Chevrolet Monte Carlo Cars & Trucks
Brake light dont turn on when pedel pressed
Light fittings, bulbs and wiring
Nov 28, 2012 | Cars & Trucks
Inside fan does not turn on
Check your relay stwich--or a new motor-check your fuse
Feb 05, 2012 | 1994 Buick LeSabre
Electric windows not working
check fuses under the dash and in the engine compartment then if they are good then check to make the lock on doors is off then check the door window stwich needs to be replaced Please rate my response thank you very much
Feb 01, 2009 | 2001 Volvo C70
Idle is erratic
I had the same trouble 2 to 3000 rpms. there is a power steering stwich on the bottom of steering pump unplug this and see if your rpms come down. Mine did,you can get a new stwich from rockauto.com for about 60.00. It took me four months and 400.00 to find this out
Nov 12, 2008 | 1999 Isuzu Rodeo
I have a 1990 F-150 the headlight trouble
it is the plug to glob it is melted in side i had the same problem
Sep 28, 2008 | 1990 Ford F150
Sony Ericsson K550i Cellular Phone Logo
50 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
