The recorder won't respond to the remote and I can't change channels or access anything with remote. Mislaid the instructions which give details to fix this. Wharfedale TU160DTR Here's hoping someone can help.
  • 1,056 Answers
Try this. Open up your pc cam then point the remote straight at the cam. You should see pulsating light on the computer screen as you look at the cams video. This tells you ar least that the remote is working fine.
Posted on Jul 03, 2010
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Replaced batterys twice but remote can't access functions
Visit this site to get more details about how to check and repair a remote control. All details are there described. Type in "Electro-help" either in Google or yahoo search box and click search.
Don't forget to type in 'hyphen' in between words of site. The site will appear as this name.
Pull up older posts there. You can repair your remote control by youself.
May 08, 2012 | Tivo C00210 Remote Control
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
The tv does not want to change channels but will only change to different inputs it will not turn off or on.
I read your problem but you have not specified your problem detail perhaps i will give you solution
1) first check your Remote control by your mobile phones camera it illuminates the light (infrared light which can be only visible with camera)
2) If it won't works then you should change remote
3) other wise you should check your TV tuner which can not able to tune channels .
I hope you are satisfied.
Thank you for giving me opportunity to solve your problem .
please give your ratings must...!!
Jun 17, 2011 | Televison & Video
Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Apr 04, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic TV Instruction Manual
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
Apr 23, 2017 | Panasonic Home Theater System System
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Manual
If you are looking for a replacement manual, please see below.
Panasonic DMR-EZ47V Replacement Instruction Manual
Apr 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
