Question about Fujitsu Heating & Cooling
Fujitsu air conditioner,general,super wave
I put my fujitsu aire conditioner(general super wave) window unit on heat and works perfect but when I set it to cool, compressor does not start
  • 883 Answers
SOURCE: Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Posted on Jul 07, 2007
  • 659 Answers
SOURCE: My Lennox Air conditioner only heats
It is possible that it's the thermostat. When you turn it into cool mode, does the unit come on at all or is it silent? If nothing is coming on, then it's likely it's the tstat. Did the tech check the refrigerant charge while he was there? He should have checked it with the auxillary heat off and the unit just in heat mode. Make sure that the condenser unit outside is coming on when you are calling for cool, If you turn it on and everything comes on, go outside and put your hand on the large copper pipe coming into the unit. In cool mode, this pipe will be cold to the touch and in heat mode, the pipe will be warm to the touch. There isn't much you can do on your own with the exception of changing the tstat. If you can answer some of the questions I have posed, I can try and give you some more answers. Just remember that a check up doesn't mean its a guarantee that something won't happen the next day, it's just that everything was in working order at the time of the checkup.
Posted on Mar 21, 2009
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
erpaalai
  • 999 Answers
SOURCE: whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Posted on Aug 15, 2009
  • 81 Answers
SOURCE: Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
My window air conditioner keeps turning off. I reset the surge protector and it goes back on and then shuts off
remove the surge protector it over heating . your unit is probley experencing a low voltage condition due to total demand due to the heat wave
Jul 22, 2011 | Heating & Cooling
I have a Fujitsu split air conditioner AOT24RNCL. The cooling, dry and fan settings are working. When I change to heating the unit trips the electric switch which is located at the power board. Any...
You have a short in the heating element. This could be something in the heating element that is conductive and needs to be removed or the element is touching the case or side of the unit. WARNING make sure power is off as the heating element is electricaly charged befor you try any repairs.
Aug 27, 2010 | Fujitsu Heating & Cooling
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu general ars40 duct type
you have to clean your A/C unit, indoor and outdoor, be sure all frost are de frosted before you run your unit again, or else it will frost again. if this not work your unit need re-gassing.
Jan 20, 2008 | Fujitsu 24R1 Air Conditioner
Fujitsu asu18R
- Check your temperature setting.
If all of your setting is ok then you need a qualified technician for this problem.
For digital setting
For manual settings
Jan 12, 2008 | Fujitsu 36CS Air Conditioner
Heating & Cooling Logo
759 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
