Question about Athearn HO RTR John Deere 650H Dozer
My 650H lgp steering is bogging down the engine when in full turn acts like it is fighting a slight turn and when it does turn it is all or nothing. It also bogs the engine under a small load. i have an error code of F393. Do you know my problem/
I have matbro ts 300 telehandler forklift -hydraulic is being trapped somewhere engine slowly bog down to stop.
off hand --check for a failed oil filter in the hydraulics blocking the return lines from the pump and valves
Mar 07, 2016 | Cars & Trucks
What causes a 1993 seadoo engine to bog down then take off, then bog down?
fuel mixing issue. A good tune up is recommended. Focus on the carburetor.
Jun 07, 2014 | Sea-Doo US Seadoo Sea doo pump off 1993 XP...
I have a Kodak 650H carousel slide projector and it won't stop advancing the slides unless you turn it off. Will the answer for the 4600 work on this type also?
The answer for the 2 machines is similar, but the repair is different. The clutch contact wire on the 650H has burned through the clutch contact. If it has just worn a notch in the clutch contact, you can bend the contact wire slightly to get it away from the notch. If the tip of the contact wire is burned off, you will be better off buying a used slide projector from someone, as parts for this generation of machines are long gone.
For the 4600 the problem is the same but the parts look different. Refer to the attached diagram for detail. The wire must rest at the center of the pad. You can use this diagram to roughly locate the similar parts in your 650H. Good Luck !!
Jan 26, 2011 | Office Equipment & Supplies
The atv starts with the choke on and idles great. When i go to throttle it bogs down and shuts off with an ocasional small backfire
you need to clean out the carburetor, the gas isn't getting through it. the bogging is caused by all the gas going into the engine cause of the choke, it dumps raw fuel into the engine and cant burn it all, there fore bogging and acting sluggish, the back firing is caused by the same thing, too much fuel going into the engine and being deposited in the pipe and igniting occasionally, clean the carb out and it will run fine
Feb 15, 2010 | kawasaki Full Suspension Mountain Bike Men
Power steering problem when turning right
I'm not sure if that truck has rack and pinion steering, or a steering sector. In either case, it sounds like you have stuck valve and the hydraulic pressure is fighting you, instead of helping you. When ever you turn the steering wheel the valve is supposed to move and direct the hydraulic oil pressure to help you steer. The valve is built into the sector or the rack and pinion, you may have to replace the assembly. There are companies that recondition those items so you might want to shop around.
Jan 09, 2010 | 2005 GMC Yukon Xl Denali
Steering wheel turns more than the wheels turn. fight to keep straight
with engine off, have someone turn the steering wheel back and forth. Check under the hood along the steering shaft for loose u-joints. check the steering box, check joints at either end of drag link(from steering box down to passenter wheel) and tie rod ends. do this with engine off so wheels dont turn. and by the way, jeeps have sloppy steering boxes from the factory, so don't expect excellent, tight steering when you're done. good luck
Nov 17, 2009 | 1995 Jeep Wrangler
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
2004 Mini Cooper S w/intermitten power steering failure
Minis have had power steering problems. I wouild contact a dealer and see if theres any updates or service bulletins.
Oct 11, 2009 | 2004 Mini Cooper
Steering problem
Your power steering engine/ pully has gone bad. needs a replacement then.
Take care and do fix it on time before you get the steering rack damaged.
Good luck.
rate this please
Apr 15, 2009 | 2005 Honda Civic
Athearn HO RTR John Deere 650H Dozer Logo
85 people viewed this question
Top Athearn Toys Experts
Jay Finke
Jay Finke
Shehu Pro
Shehu Pro
Are you an Athearn Toy Expert? Answer questions, earn points and help others
