My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
    Novelist:
    Champion:
  • 226 Answers
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty.
Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Posted on Jul 03, 2010
My aspire switch 10 won't power up. When it is plugged in the amber light on the tablet lights up and that is all.
Amber usually indicates that the batter is charging. If it never changes to green, you may need a new battery. Try taking out the battery and plugging in the charger. Sometimes a dead battery can actually block the power from getting to the device.
Oct 28, 2014 | Acer Genuine Ac Adapter Aspire One D 250...
I want to reset my acer aspire one D250-1042 for sale
This model Acer has a restore partition on the hard disk.
Check out this WEB site for instruction on restoring the laptop back to the out of the box condition.
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Oct 21, 2012 | Acer Aspire One D250-1042 Laptop Computers
Where is buy a batterie for laptop look at a site www.elecachat.fr
The best place to buy a battery for your laptop is eBay. Once the site comes up just put in the search box something like Acer Aspire One battery. Click the link below and type in the search box "Acer Aspire One Netbook Battery" (without the quotes) and click Search. When the search results come back Select to only see the Buy It Now merchandise and Sort the list by lowest price first. The first couple of items will be ac adapter and power cord, but once you hit the prices in the $20 range you will start seeing the battery. Click the link below
to see a all the batteries.
http://www.ebay.com
The link below will take you directly to one that I selected that costs $23.99 including FREE Shipping. Please note that the battery fits the Acer Aspire One ZG5, A110, A150, D150 and the D250 which is your model.
http://www.ebay.com/itm/New-Netbook-Battery-for-ACER-ASPIRE-ONE-ZG5-A110-A150-5po-/250979671222?pt=Laptop_Batteries&hash=item3a6f8ddcb6
Apr 24, 2012 | Acer Aspire One AOD250-1326 Netbook
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
We bought in the USA a KAV60/AOD250 and use here in the UK with an adaptor for the different electricity. Unfortunately something has gone wrong with the leads as it sometimes shows up the notepad is on...
Here is the link to a company in Canada that has replacement AC adapters for Acer. The AC adapter for the Acer Aspire One D250 has a DC output of 19 volts at 1.58 amps which is what the AC adapter at the following link has. The price is C$12.99 so it is relatively inexpensive.
http://www.battdepot.ca/model/acer/aspire+one+a110-1295/ac19v30u.aspx
If you are handy with a soldering iron, you might try wiggling along the wire from the adapter to the plug on the D250. You might find one point where the wiggling consistently turns the D250 battery led on and off. If so then you can cut the offending section out and resolder the pair of wires back together. Make sure you don't switch the wires around. The plug has a negative shell and a positive tip. Should check with a voltmeter before you solder the wires and also recheck afterwards at the plug itself. Also make sure the wires at the solder point are well insulated so as not to short out across the pair. If you have in any doubts about doing this kind of repair, it would be better to just buy a replacement adapter.
Finally, you may be able to find an AC adapter retailer in the UK so as to possible have lower shipping costs. All I did was just google search "acer aspire one ac adapter"....
Feb 01, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Acer Aspire one D250-1371. no longer charging battery or powering up with AC adapter. Ac adapter works tried it on other aspire. battery works on other systems. this system will not start up no matter what...
The power receptacle in the laptop (where you plug in the AC adapter cord) might be damaged. In order to diagnose this problem, please follow the diagnosis outlined in this article:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Next, if you made sure that it is not a power receptacle problem, then you will have to disassemble your laptop, removing one component at a time & testing. First start by removing the battery, hard drive, RAM modules, CD/DVD drive, wireless card adapter, .... etc. Continue removing the parts till you only have the motherboard, testing after you remove each component. Once you get the power LED on the power adapter to glow when plugged to the laptop, you then know that the component you just removed is the faulty one that needs to be replaced. If you reach the point where all components have been removed & only the motherboard is remaining, then the mother board is the defective part that needs to be replaced.
Oct 16, 2010 | Acer Aspire One PC Notebook
Aspire One Netbook 8.9" Notebook : I have an Acer Aspire One D250 great little comput...
If you are looking for Drivers then I would recommend an Automatic Driver Download Tool that can detect all your installed hardware, search, download and install all the required latest model and manufacturer specific drivers automatically.
Regarding the Battery, some intelligent batteries remember the charge. If the first time you do not let it discharge completely, then it remembers that setting and never charges more than that. So just try discharging your batteries to zero percent and try recharging it. I am sure it will charge to 100% this time. Read more at www.fixpcfreeze.com
May 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
Ihave a netbook Acer Aspire one D250-1116
haha same here and i have an acer aspire one too and i live in a VERY rural area people in the next town over haven't even heard of it. i heard you can get those things on ebay pretty cheap
Dec 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
