Question about Remington Precision HC-8017 Hair Trimmer
Would not cut hair sticking all the time maybe need new blades
  • 76 Answers
If you have not already tried this, the first thing you should do is lubricate the blades. you can get shaver oil at any salon or beauty supply store.
Posted on Aug 05, 2010
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
I bought a 19 piece and i can't cut my hair
It soulds like the blades are too far back. There is an adjustmebt piece to the right or left of the blade that is about 1 1/2-2" long and it slides forward and backwards.
Ths will adjust the blade depth. It sounds like the blades may be set too far back to cut your hair, this has to bring the 2 blades together so you have much less free edge on one side, so what you do is slide ths blade by adjusting the handle and bring the blades to just where one side is slightly shorter than the other less than 1 cm. Then make sure the guard is off and slde the adjustment head is set and then try it agan. Unusually it is the problem if it does not cut or the blades have come loose. Hope that helps.
Apr 05, 2009 | Conair HCT-426 Hair Trimmer
Oster Golden A5 Clippers will not cut
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Feb 28, 2009 | Oster Golden A5 1-Speed Universal Motor...
Adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Sep 05, 2008 | Andis 04603 Hair Trimmer
Oster A5 single speed clipper not cutting
not usually we will not sharpen blades that are worn out as we cannot charge for something that does not cut!
make sure your blade is connecting with the drive of your clipper they might need an extra push depending if the blade has been adjusted.
Jul 17, 2008 | Oster 76974-160 Hair Trimmer
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Remington Precision HC-8017 Hair Trimmer Logo
531 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
