Question about Kodak EASYSHARE Z1485 IS Digital Camera
Lense is stuck extended and camera will turn off 10 seconds after I try to turn it on.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 03, 2010
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
Lense won't extend when camera is turned on
lens has been damaged and it's most likely not worth repairing. lens can look fine but internal damage will require more money than it's worth. recommend replace
Sep 25, 2009 | Cameras
Lense was stuck out did what toothy said now the lense is stuck i
Hi!
Please follow the troubleshooting given below to resolve the issue:
(a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds.
(b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged.
(c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
A730 Lense extended
yeah I got screwed buying a samsung camera too.
Samsung screwed me out of a rebate on a computer monitor before too.
I will never buy another samsung product!!!!
May 26, 2008 | Samsung Digimax S730 Digital Camera
Casio Digital Camera ex-s770 will not open
Hi, this is a problem alot of people get having with this type of camera.
It could be one of a couple of things first check the battery is fully charges as a faulty battery would cause this problem, do you have a switch on the camera that lets you see the pictures stored on it without opening the lense, not all makes and models do this some have switch you can slide and some is just push button the push button you cant do this.
So if yours is the push button one then the only thing to try if the battery isnt the problem is looking and removing anything thats caught in the side of lense.
Ok try removing battery and any mem cards if you have any in it then bang the camera firmly into the palm of your hand sort of shocking the camera to dislodge any thing thats stuck in the side of lense do this few times then replace battery and switch on usually this solves the problem.
If not then when you switch camera on grab the lense and help it come out taking it past where it gets stuck be gentle try this few times and see if camera comes on.
Once the lense is passed certain point the camera should come on.
So give that a try it does sound like something is jamming the lense so try pulling it out gently only do it when its supposed to be coming out when it trys to go back in let go again try this few times.
Failing this then the problem could be that either the camera has been put down with the lense open and forced the lense motor damaging it or the other thing that people tend to do is switch camera on acidently whilst its in pocket or case so that it switches on but the lense is blocked from coming out this causing damage to lense motor.
If the problem is in fact the lense motor then their is no way of getting this repaired they just dont repair these and you cant get the parts like lense motor no camera shop will even look at them as you cant get parts and also price of repair would cost more than replacing the camera.
Also check to see if your lense turns round as its coming in or out if it does this then try turning the lense as its coming out.
Let me know how you get on ok and ill try assist you further
Feb 22, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Kodak EASYSHARE Z1485 IS Digital Camera Logo
325 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
