Question about Imperial IFS40 Deep Fryer
ON GOING I HAVE IFS40 AND I HAVE THE THROMPILE REPLACE3 TIMES IN 1 YEAR AND IT IS OUT AGAIN RICK
    Scholar:
  • 68 Answers
Some one needs to take a millivolt reading on the thermopile. There are different types. But I believe on your type of fryer, the thermopile should put out at least 300 mV. Your gas valve is probably designed to work from 250mV to 750mV. You need a meter to get to the bottom.
In your case, I expect a new thermopile is able to make a bad gas valve look good. A new thermopile mV output is most always higher than an old one.
Posted on May 06, 2008
What would cause the change engine oil light to malfunction and not reset on a 2003 Chevy express van 1500 if procedure has been done correctly?
with the key on/engine off floor the gas pedal 3 times the hold it down till the change oil light start blinking and go away,some times it take more than 10 sec,if it didn't work try it again,some times you have to try few times,to get it done
Aug 07, 2014 | 2003 Chevrolet Express
The bar is not turning and there is no suction
1) test the belt for broken or worn, replace
2) test for pulley worn or defective replace
3) test the motor for worn brushes, lubrication, bearing repair
4) test for bar worn or defective repair or replace
5) hose is clogged, repair bag/tank full, need emptied.
God bless you
Jul 14, 2012 | Vacuums
WONT START
1) test the outlet wall, try to put some lamp for to see if there are voltage
2) reset the c. breaker or blown fuse replace
3) test the power cord
4) try again. if the problem persist you must test the following a) wiring break or open b) thermostat c) compressor d) overload relais e) selector switch for open f) control board
God bless you . see the diagram attached.
Jun 22, 2012 | LG LW1010ER 10,000 BTU Window Air...
Green clean light is flashing cant start dishwasher on or turn off light
1) see the door switch if open or defective and replace see the diagram
2) test the fuse inside for open and replace, see the relais if is closing and clean the contact or replace
3) resolder the colder joint every point, otherwise you must change the board.
God bless you
Jun 20, 2012 | Dishwashers
My Broan central vac is 25 yrs. old and making a lot of noise in the upper canister, but sucks okay, what is it? #CV40
1) motor bearing replace
2) brush roller bearing defective replace
3) any other parts loose or worn.
God bless you
Jun 19, 2012 | Vacuums
My kenmore dishwasher will not start. Only the options buttons light up.
1) power home. c.breaker tripped reset or blown fuse
2) door switch, test for open or defective replace
3)wires for open, break or burn, repair
4)timer or selector swtich, test for open dirty contacts, loose wires, break or burn, or open switch replace.
God bless you
Jun 19, 2012 | Dishwashers
It makes a noise and wont tumble
you have 2 kind of problem:
1) Noises:
Rollers
worn rollers replace
Idler pulley
worn replace
Glides
worn plastic or nylon replace
Rear drum bearing
worn bearing replace
Blower wheel
clogged, clean it.
2)Not Tumble:
1) Clean the blower fan for clogged
2) Rotate easy the motor manual, otherwise motor defective replace
3)belt worn or defective.
4) door switch, test for open or defecive. see the video.
5_24_2012_1_06_17_pm.gif5_24_2012_1_06_34_pm.gif5_24_2012_1_06_59_pm.gif5_24_2012_1_07_19_pm.gif5_24_2012_1_07_45_pm.gif
May 23, 2012 | GE Profile Wizard DPSE592EAWW Electric...
Vent hood lights dont turn
1) test the breaker from your horme that connect to HOOD
2) test the swithc by continuity , and replace
3) test for loose wires
4) test the lights if are burn.
good luck, sincerely. G-d bless you
ernesto cuadramanagua, nicaragua c.a
Dec 14, 2011 | Kitchen Ranges
Opener only raises the door one foot.
IF THE DOOR IS BALANCED TRY ADJUSTING THE SENSITIVITY.
THE DRIVE SHOULD BE LUBED WITH WHITE LITHIUM OR GENIE LUBE 2 TIMES PER YEAR TO KEEP THE UNIT QUIETER AND PREVENT EXCESS WEAR.
IF YOU USE THE WRONG LUBE - GREASE ETC. THE UNIT WILL GET GUMMED UP AND WILL HAVE PROBLEMS IN COLD WEATHER.
ONCE YOU ADJUST THE SENSITIVITY YOU SHOULD BE OK.
Aug 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Imperial IFS40 Deep Fryer Logo
113 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
