Question about IBM ThinkPad T30 2366 Notebook
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says vga graphics card shadowed. how can i fix if it wont boot? im thinking the bios are wrong.
  • IBM Master
  • 32,281 Answers
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Posted on Jul 03, 2010
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
I have a T40 IBM that just got the 1802 error. downloaded a bootable fix that I made to a CD. Set both startup and network to look for the CD drive first. Cannot get past the double beep on the POST test...
To correct this issue, you will need to remove the PCI wireless card from your laptop or disable the mini PCI settings in the BIOS menu.
On IBM's, the Mini PCI card slot is usually at the back of computer.
After removing card or disabling the
mini PCI settings in the BIOS menu, boot your computer. Make sure to update your BIOS. The new BIOS version can be downloaded from the manufacturer's website.
(http://www-307.ibm.com/pc/support/site.wss/MIGR-51708.html).
This issue has been corrected in the latests BIOS updates released.
After updating the BIOS, you can reseat the PCI Wireless card or enable the mini PCI settings in the BIOS menu.
Note that once you have removed the wireless card, you will not have wireless connection until you update the bios and replace it.
Hope this helps.
May 19, 2011 | IBM ThinkPad R40 2722 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Windows wont load
Press F8 during the initial boot process until you get to a boot menu. Select "Safe Mode".
Nov 06, 2008 | IBM ThinkPad R50e Notebook
XPS 600 BIOS setup problem
light 1&2 is a memory configuration error.make sure you have the memory in correctly
Sep 06, 2008 | Dell XPS™ 600 PC Desktop
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
Stopping at the BIOS Splash screen
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Feb 26, 2008 | IBM ThinkPad T30 2366 Notebook
Error message, need help
1. Turn off laptop, unplug all devices and cables.
2. Flip laptop upside down on towel (avoids scratches)
3. Open the PCI panel (you need screwdriver to fit screws)
4. remove the PCI card inside (probably 3rd party WIFI card)
5. reattach AC/PSU cable and start laptop
6 If it starts properly now, you either had a bad PCI card, or it was improperly installed. You can try installing it again (turn everything off first). Sometimes this error is just from the card getting loose, or oxidation on contacts. Insert and remove it 2-3 times to see if it works then. Let me know.
Feb 12, 2008 | Acer Aspire 5100-5022 Notebook
IBM ThinkPad T30 2366 Notebook Logo
180 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
